Fitz Posted February 10, 2021 Report Share Posted February 10, 2021 3 hours ago, Dusty Chalk said: decided the triangle would be too claustrophobic, so going to make a trapezoid Is that what the kids are calling it these days? Kinky. 2 Quote Link to comment Share on other sites More sharing options...
n_maher Posted February 10, 2021 Report Share Posted February 10, 2021 11 hours ago, Grahame said: The cut doesn't look all that clean .. I think laser table technology has advanced considerably in the last 50+ years. 1 Quote Link to comment Share on other sites More sharing options...
VPI Posted February 10, 2021 Report Share Posted February 10, 2021 Evidently the sole support guy for Incra is named Barry, and he also never answers the phone and takes forever to return calls. Sort of a Texas Jessem. 1 Quote Link to comment Share on other sites More sharing options...
Dusty Chalk Posted February 10, 2021 Report Share Posted February 10, 2021 16 hours ago, Fitz said: Is that what the kids are calling it these days? Kinky. That wasn't the double-entendre I expected, but it's the one I lollered. Quote Link to comment Share on other sites More sharing options...
naamanf Posted February 13, 2021 Report Share Posted February 13, 2021 Needed some lower profile hold downs. First time cutting plastic, worked great, except the plastic is to flexible to work well for hold downs. Time to see what Amazon has. 2 Quote Link to comment Share on other sites More sharing options...
dsavitsk Posted February 13, 2021 Report Share Posted February 13, 2021 Have you tried double sided tape? Quote Link to comment Share on other sites More sharing options...
naamanf Posted February 13, 2021 Report Share Posted February 13, 2021 7 minutes ago, dsavitsk said: Have you tried double sided tape? Okay for small parts, but really not feasible for doing larger panels or sheets. Quote Link to comment Share on other sites More sharing options...
dsavitsk Posted February 13, 2021 Report Share Posted February 13, 2021 How about phenolic sheets? 1 Quote Link to comment Share on other sites More sharing options...
naamanf Posted February 13, 2021 Report Share Posted February 13, 2021 3 minutes ago, dsavitsk said: How about phenolic sheets? I was going to order that or delrin. Quote Link to comment Share on other sites More sharing options...
morphsci Posted February 14, 2021 Report Share Posted February 14, 2021 A “What’s Playin Now” unit 6 Quote Link to comment Share on other sites More sharing options...
swt61 Posted February 14, 2021 Report Share Posted February 14, 2021 1 hour ago, dsavitsk said: How about phenolic sheets? Good idea! Quote Link to comment Share on other sites More sharing options...
dsavitsk Posted February 14, 2021 Report Share Posted February 14, 2021 1 hour ago, naamanf said: I was going to order that or delrin. Delrin is quite soft and bendy Quote Link to comment Share on other sites More sharing options...
Kerry Posted February 14, 2021 Report Share Posted February 14, 2021 I use HDPE for that stuff. I’ve always had problems working with delrin. It melts as you cut it. 1 Quote Link to comment Share on other sites More sharing options...
dsavitsk Posted February 14, 2021 Report Share Posted February 14, 2021 Delrin definitely lasers better. Danger is that it burns with an invisible flame, so if it catches you don't know until it's gone. Blank pcb material is another option Quote Link to comment Share on other sites More sharing options...
swt61 Posted February 14, 2021 Report Share Posted February 14, 2021 1 hour ago, Kerry said: I use HDPE for that stuff. I’ve always had problems working with delrin. It melts as you cut it. Not to mention the sustainability of this product. I could only imagine what kind of cool, carved outdoor furniture Naaman could make on his Ping Pong table. 1 Quote Link to comment Share on other sites More sharing options...
VPI Posted February 14, 2021 Report Share Posted February 14, 2021 Working on a cross cut sled. I am going with 24” wide as I think that is about as big as I can manage on the TS. How thick are you guys making your fences on the crosscut sleds? I glued up two 3/4” BB plywood pieces and plan to add a block where the blade lines up. Is 1.5” thick enough for the squared fence? Quote Link to comment Share on other sites More sharing options...
swt61 Posted February 14, 2021 Report Share Posted February 14, 2021 For a sled of that size, it's thick enough. 1 Quote Link to comment Share on other sites More sharing options...
VPI Posted February 14, 2021 Report Share Posted February 14, 2021 Another stupid question. As I do not want to set off the saw stop safety features. How long do I need to wait after glue up to start cutting down the two pieces of plywood? Been drying for 4-5 hours. Quote Link to comment Share on other sites More sharing options...
naamanf Posted February 14, 2021 Report Share Posted February 14, 2021 46 minutes ago, VPI said: Another stupid question. As I do not want to set off the saw stop safety features. How long do I need to wait after glue up to start cutting down the two pieces of plywood? Been drying for 4-5 hours. I would wait 24 hours to safe, or turn the safety feature off temporarily. 2 Quote Link to comment Share on other sites More sharing options...
dsavitsk Posted February 14, 2021 Report Share Posted February 14, 2021 (edited) 4 or 5 hours should be fine. For glue to trip the saw, it needs to create a path to ground. Merely encountering even wet glue in a joint won't cause a trigger. Similarly, hitting a nail won't cause it to trip unless the nail is also touching something else (the table top, you, a metal fence, etc.) It's why wet wood can cause a trigger as the wetness connects the blade to the table top. There is a test feature so you can see if something will cause it to trip before turning it on. Edited February 14, 2021 by dsavitsk 2 Quote Link to comment Share on other sites More sharing options...
VPI Posted February 15, 2021 Report Share Posted February 15, 2021 Set up the Murder Machine with its tiniest bit for an almost imperceptible to the eye round over for the sled tops. 4 Quote Link to comment Share on other sites More sharing options...
VPI Posted February 15, 2021 Report Share Posted February 15, 2021 Is anyone using these Zeroplay mitre bars? Seem like a nice way to get them set right, but they seem kind of short for the larger sled. https://www.microjig.com/collections/zeroplay Quote Link to comment Share on other sites More sharing options...
swt61 Posted February 15, 2021 Report Share Posted February 15, 2021 Wasn't aware of them. Thanks. I'd imagine you could double them up if necessary. Maybe even cut the second one down a bit? 1 Quote Link to comment Share on other sites More sharing options...
VPI Posted February 15, 2021 Report Share Posted February 15, 2021 I kind of like the idea of shop made rails as you just lay the sled down on them with some glue and everything is perfectly aligned. With these I guess I have to measure the distance between rails and add 3/8 for the mounting position. With a crappy plastic top, not sure the mitre slots will be uniform. Quote Link to comment Share on other sites More sharing options...
dsavitsk Posted February 15, 2021 Report Share Posted February 15, 2021 You'd still probably align them the same way. Put them in the slots, put some double sided tape on them, set the sled on top, flip it over and drill pilot holes through the threaded inserts, or just trace around the rail to find its position. If they are sufficiently slop free, they shouldn't need to be very long. I've used the incra version. They are fine, but I usually just end up using wood rails instead. That said, I have never built a forever sled. I build sleds as needed for particular projects, so I don't care if the rails swell in 6 months as it will be in the trash by then. This is probably not a best practice, though. FWIW, I do like Microjig. This is one of my favorite things: https://www.microjig.com/collections/grr-rip-block 3 Quote Link to comment Share on other sites More sharing options...
