shellylh Posted June 26, 2016 Report Share Posted June 26, 2016 I am looking to get a new electric toothbrush (my Oral b is splitting apart at the top and doesn't seem waterproof anymore). I am trying to decide between an Oral B or Sonic Care. I have sensitive teeth. Quote Link to comment Share on other sites More sharing options...
TMoney Posted June 26, 2016 Report Share Posted June 26, 2016 Not a toothbrush recommendation, but have you ever thought about getting a online/print subscription to Consumer Reports, Shelly? I just get the monthly print version, but they test all nature of things from toothbrushes to tires vigorously and impartially. I find it helps a lot with these types of buying decisions where all you really know are the brands. I'm almost always satisfied with the products they recommend. Just a thought. Good luck with your purchase! Quote Link to comment Share on other sites More sharing options...
Grahame Posted June 26, 2016 Report Share Posted June 26, 2016 The wirecutter / sweethome have in depth recommendations for everyday things. Here's what they say about electric toothbrushes http://thesweethome.com/reviews/best-electric-toothbrush/ 1 Quote Link to comment Share on other sites More sharing options...
MexicanDragon Posted June 26, 2016 Report Share Posted June 26, 2016 Shelly, TheSweetHome and TheWirecutter are fantastic sites. I used to do tons of research on things (a hobby, because I'm often bored,) and the things I had researched greatly, I checked out the thoughts of TSH/TWC. What I found lined up rather well with what they had, and their reasonings for their choices are fairly sound. With some of the electronic stuff, they had people who I'd trusted reviews of for years, so it seems like they get good people. FWIW, I have an Oral-B 5000 (a more expensive version of what they recommend) and I dig it. it's 150$ in stores, but my dentist had it for 100$, with 67% more heads, toothpaste, floss, and mouthwash, and a 20$ rebate. Since I have tax on amazon, and none of this, it wound up being 25$ more than the entry level one, with some bonus stuff that gets used. My rec? If you like the sensitive head for your Oral-B, get a 1000 and some sensitive heads for it. If you didn't love it, give the Sonicare a shot. Also, you can probably keep your old Oral-B around and use it to clean grout/around small things in the kitchen/bathroom. If you did that and went with the new Oral-B, you could still keep using old brush heads for cleaning (I'm sure you'd be fine just soaking them in some alcohol to sanitize them, right?) **BRENT** Quote Link to comment Share on other sites More sharing options...
ironbut Posted June 26, 2016 Report Share Posted June 26, 2016 Checked out TheSweetHome. Very cool site! Thanks for the tip. I hated the Sonicare. I have a tendency to get gum problems and it made things worse. I have a nice one that is use for household cleaning now. Of course, it could have been user error but that was my experience. Quote Link to comment Share on other sites More sharing options...
swt61 Posted June 26, 2016 Report Share Posted June 26, 2016 57 minutes ago, MexicanDragon said: Shelly, TheSweetHome and TheWirecutter are fantastic sites. I used to do tons of research on things (a hobby, because I'm often bored,) and the things I had researched greatly, I checked out the thoughts of TSH/TWC. What I found lined up rather well with what they had, and their reasonings for their choices are fairly sound. With some of the electronic stuff, they had people who I'd trusted reviews of for years, so it seems like they get good people. FWIW, I have an Oral-B 5000 (a more expensive version of what they recommend) and I dig it. it's 150$ in stores, but my dentist had it for 100$, with 67% more heads, toothpaste, floss, and mouthwash, and a 20$ rebate. Since I have tax on amazon, and none of this, it wound up being 25$ more than the entry level one, with some bonus stuff that gets used. My rec? If you like the sensitive head for your Oral-B, get a 1000 and some sensitive heads for it. If you didn't love it, give the Sonicare a shot. Also, you can probably keep your old Oral-B around and use it to clean grout/around small things in the kitchen/bathroom. If you did that and went with the new Oral-B, you could still keep using old brush heads for cleaning (I'm sure you'd be fine just soaking them in some alcohol to sanitize them, right?) **BRENT** Biscuit residue requires more power. 1 Quote Link to comment Share on other sites More sharing options...
n_maher Posted June 26, 2016 Report Share Posted June 26, 2016 Oral-b 7000 user here. Had a 5000 for like 5 years and the battery just wore out. The 7000 has been great. 1 Quote Link to comment Share on other sites More sharing options...
shellylh Posted June 26, 2016 Author Report Share Posted June 26, 2016 I've looked at a bunch of reviews (including thesweethome) and have also had consumer reports in the past. I just wanted opinions from people I know. Just wondering if anyone had a good or bad experience with one or the other. I have the Oral B 5000 right now so maybe I'll just stick to that. The only reason I'm replacing it is that I think water is leaking into it since it is no longer sealed at the top so I'll probably just recycle it. It's probably not great for water to be getting into electronics. Quote Link to comment Share on other sites More sharing options...
n_maher Posted June 26, 2016 Report Share Posted June 26, 2016 If it still works I'd just run it until it quits. No reason to care if water is getting into it and shortening its life. 2 Quote Link to comment Share on other sites More sharing options...
MexicanDragon Posted June 26, 2016 Report Share Posted June 26, 2016 If it still works I'd just run it until it quits. No reason to care if water is getting into it and shortening its life. This. **BRENT** 1 Quote Link to comment Share on other sites More sharing options...
shellylh Posted June 26, 2016 Author Report Share Posted June 26, 2016 Ok, maybe the small ring at the top doesn't let too much water it. I can't get it to go back into place probably because of all the gunk on it. Wouldn't it be bad if water got onto the circuit and especially on the battery? Quote Link to comment Share on other sites More sharing options...
swt61 Posted June 26, 2016 Report Share Posted June 26, 2016 The battery will be a sealed unit, so no worries there. If it kills the circuit board tomorrow, then you got one more day out of it than if you replaced it today. 2 Quote Link to comment Share on other sites More sharing options...
CarlSeibert Posted June 30, 2016 Report Share Posted June 30, 2016 What Steve said. That, and I replaced my ancient Oral- B with a Sonicare (whatever one that's two for a hundred bucks at Costco) and I like it just fine. Sent from my SPH-L720 using Tapatalk 1 Quote Link to comment Share on other sites More sharing options...
Absorbine_Sr Posted June 30, 2016 Report Share Posted June 30, 2016 Two years ago I had a crapload of dental work done, because I was an ass for many years and did not take good care of my teeth. Even during that time I used an Oral B. My new dentist recommended a Sonicare. I bought one and have loved it since. And my exams since using it have been excellent. So that's my 2 cent recommendation. 1 Quote Link to comment Share on other sites More sharing options...
Aimless1 Posted June 30, 2016 Report Share Posted June 30, 2016 Steve is right so no worries there. My dentist has always recommended the Sonicate. Sadly, my dental history is much like brother Mike with similar results. Quote Link to comment Share on other sites More sharing options...
jvlgato Posted July 1, 2016 Report Share Posted July 1, 2016 I've had both and liked both, but prefer the Sonicare. 1 Quote Link to comment Share on other sites More sharing options...
justin Posted July 4, 2016 Report Share Posted July 4, 2016 I use a Diamondclean with Sensodyne toothpaste Quote Link to comment Share on other sites More sharing options...
