July 22, 20179 yr comment_770088 If dual tube input. One tube as upper device and the other as lower like T2 or one tube each side? Report
July 22, 20179 yr comment_770089 I wanted to compare the dual input tubes (like in the T2) against the single. I'd build the dual first first though. Report
July 22, 20179 yr Author comment_770096 one comment about the tubes, have tried many tubes on testbench, 12au7,12ax7,12at7,7308 etc you need a mu of at least 33 and a transconductance of at least 12500 Report
August 31, 20179 yr comment_773679 Anyone about to build this, Megatron, etc and don't want to use a dropping resistor, I might have some spare power supply boards for tube front ends soon. Works up to 250V no problem, 300V is possible if you find caps that fit and heatsink appropriate parts properly. Report
October 4, 20179 yr comment_775764 How come T8000 fires is slowly fading away ? We need more fuels ? Report
October 4, 20179 yr comment_775775 Sounds like the consensus was t-POS...Sent from my iPhone using Tapatalk Report
October 4, 20179 yr comment_775779 56 minutes ago, Pars said: Sounds like the consensus was t-POS... Sent from my iPhone using Tapatalk What ? T-Perfected-Over-Standard ? JK, but that is sad....we need Stax to be serious again Edited October 4, 20179 yr by Whitigir Report
October 4, 20179 yr comment_775785 i'm mostly just waiting for the version with ss output and tube ccs Report
December 2, 20178 yr comment_779888 On 2017-07-06 at 7:26 PM, kevin gilmore said: power jumper block cleaned of all the epoxy j1,j3,j4 for 100v remove all others j2 j3 j5 for 120v remove all others j5,j6 for 240v remove all others and servo board pictures, unnecessarily complex tube rollers are going to have a lot of trouble with this, the servo has a pretty limited range, and the Russian similar's definitely will not work How to make the servo less complex? Report
December 2, 20178 yr Author comment_779890 servo attaches directly to the plate of the tube. similar to T2. no way to make less complex. Report
December 2, 20178 yr comment_779901 Moving the servo to the cathode would that be a good idea? Report
December 2, 20178 yr Author comment_779908 better idea would be to use the servo from the kgsshv-carbon but does not compensate for the tube drifting section to section Report
May 1, 20188 yr comment_789132 Draft of dual 6922 input (similar to T2 input), with current tunnel (as Carbon etc.) Voltage cross 2sa1486 580V and 700mW of heat. Report
August 25, 20188 yr comment_794492 Trying to use the above draft in a board layout. The print out is roughly a quarter of the original DIY T2 board in size. Output section reminds of T2 less unnecessary parts. This is progressing very slowly and I’m thinking it might go into trash can before it gets to the CNC router. Hmm.. probably trash can. Report
August 25, 20188 yr comment_794498 More paper work. Width incl. heat sinks 9.5in and length 7.9in. No angel brackets sands mounted direct on heat sinks, saves 1.6in. Report
August 25, 20188 yr comment_794505 I like it, you are going in the other direction from the original T2, small amp chassis and a huge PSU. Report
August 26, 20188 yr comment_794535 Very nice Joachim! With the micro golden reference HV power supplies (which do work very nicely) and lower voltage (less caps) you could get the power supply size down a bit as well Report
August 26, 20188 yr comment_794551 Thanks. Yep, your micro power supplies are very interesting. My idea is to make a PSU with +/-15V, +220V, +400V and -460V. Shooting from the hip - how about producing 580V (BIAS) by GRHV? Report
August 27, 20188 yr comment_794571 All components are now on the right channel board. More work is to be done but so far it has gone quite nice. By the way, I think I've learned netlisting and I love it - tells me when I'm out of track. Report
August 27, 20188 yr comment_794572 Netlisting is even better if we were ever to bother with schematics...which we never do. Report
August 27, 20188 yr comment_794574 29 minutes ago, spritzer said: Netlisting is even better if we were ever to bother with schematics...which we never do. You guys have it in you - the schematic in your heads. I’ve no head and therefor I use schematic which I derive from your layouts hihihihi Edited August 27, 20188 yr by JoaMat Report
