Apogee Duet Kicks Ass
Are there any known DIY modifications that can enable the Apogee Duet to become compatible with Microsoft Windows?
Actually, I did just come up with a DIY method for getting the Duet to work with Windows, since I am DIY master.
1. Buy Duet
2. Sell Duet
3. Buy Pico
4. ...
5. Profit
  • Replies 404
  • Views 94.9k
  • Craig Sawyers
    Craig Sawyers
    I saw Apogee and immediately thought  But then I clicked the link, and it wasn't *that* Apogee! Equally interesting though.
  • blessingx
    blessingx
    Decade bump. Anyone else excited about the Duet 3? https://apogeedigital.com/blog/introducing-apogee-duet-3
  • I had a pair of Apogee Duetta Signature in the early 90’s. It’s the one piece of audio gears I regret most for foolishly selling.
1. Buy Duet
2. Sell Duet
3. Buy Pico
4. ...
5. Profit
:laugh: I started at step three.
1. Buy Duet
2. Sell Duet
3. Buy Pico
4. ...
5. Profit
Yeah, thanks a fucking bunch posty.
I just read that and burst into laughter and everyone looked at me like I was a nutbat. ;D
I like your thinking though.
:rofl: For a second I thought you guys were not paying attention. ;D
I am fine, the weather is not so good though. How about you?
Goodbye.
Huh? I have no plans to log off at this moment. Where are you heading off to? ^-^
A very reasonable way to use the Duet with Windows would be to use a "Macintosh" simulator and run it in there. Google showed several possibilities. I have no idea how good or complete the simulations are. If you can find a good one, it would do the trick.
It'd have to include core audio, which seems unlikely :)
Posty's post makes it sound like the Pico > Duet. I'm not good at describing sounds well but I can't wait to AB it with my friend's duet. What I wish was a plug-and-play Duet, Apogee is missing out by not releasing one.
nah, i haven't heard either.
  • 4 weeks later...
Wouldn't the current entry level mini be the best bang for the buck? 1.83 GHz C2D, 1 GB of RAM and 80 GB HD for $600.
that core solo should be plenty fast for music (and, frankly, most things, as it's way faster than the G4 systems i was stuck using for years), that's what i would suggest people get.
I have the last ppc mini Mac (1,5 Ghz G5 irc) it's more than fast enough to "normal" mediacenter duties (music, ripped dvds @ ~2Mb/s etc). I guess the solo should be at least as fast.
But unless I was on a budget, I would go for a dual core as two hanging process are better than one :)
Primarily using this as a DAC + headphone amp is disappointing? How about relative to the E-MU 0404 USB functioning in the same capacity?
the duet should be better than the e-mu 0404. the headphone out of the 0404 usb definitely bottlenecks the performance of the unit. grawk has stated the headphone out of the duet is better than the one out the mini-dac, which IMO, is much better than the one out of the 0404.
Actually you might be able to approximate some kind of solution to use a duet in windows with cygwin (linux has coreaudio ports). If it were me though, I would just get a hacked version of osx.
Not to go off topic, but are there any alternatives to the supplied breakout cable for RCA? I saw someone made one with RCA and cable already attached, but I'd like to use my own cable with as little or no other cable in the signal path.
Get the pinout from Apogee (or from HF, I believe it's been posted there somewhere).
