Speaker Porn
Did you know it took a speaker manufacturer to produce the best amplifier in the world?
Originally, we developed the Arbiter for internal use only; however, the interest was overwhelming for this magnificent amplifier, and because of this, we decided to produce a limited batch of 50 complete sets.
The Arbiter was, and still is, unlike anything else on the market. With its battery-powered design, over 1.000-watt output power, a bandwidth from nearly DC to 300 kHz, and probably the most elaborate volume control ever created, the Arbiter still ranks among the very best even 20 years after its birth.
12669542_1042474902462895_87733743059075
12322769_1042474979129554_39640240995412
12694808_1042474919129560_50250725632547
  • Replies 2.4k
  • Views 673k
  • Craig Sawyers
    Craig Sawyers
    Ah - the good old battleship grey Cambridge Audio livery. It was panned by the reviewers, as were the buttons on the CD player (they described them as reminiscent of poking dead flesh). Very unfair, b
  • R5s arrived:
  • I dunno, can i post this here? The leather was just an idea - making some matching wood pulls would be cool - maybe when things die down at M&O of course my speaker cables are too short
Guitarist Dream System
Audiophile prior art
Because ....
I'm speechless.  Who would?  Why?
Back on planet earth, ML recently introduced the Neolith; the design brief was anything goes with the only requirement that it fits though a standard domestic door.  At around $100k you could buy 50 of them for the solid gold microsystem above.
More cents than sense?
Mmm...line array electrostatics...(and by that I mean the 50 Neoliths)...
I was just trying to figure out what you were going to do them once you got them through said domicile sized door.  You certainly weren't going to arrange them back to front -- that might cancel each other out....er, no, it would generate some very nasty comb filtering.
  • 4 weeks later...
Lots more Bavarian pr0n in high def here
http://www.my-hiend.com/vbb/showthread.php?10531-2016%E5%B9%B4%E5%BE%B7%E5%9C%8B%E6%85%95%E5%B0%BC%E9%BB%91High-End%E9%9F%B3%E9%9F%BF%E5%B1%95%E5%AF%A6%E6%B3%81%E5%A0%B1%E5%B0%8E-Munich-High-End-Show
e.g.
as for what this is ...
13177132_10204514252454614_6389653150603
google image search came up a blank ....
but it was here with some friends
But  at the apatura-audio display
http://www.apertura-audio.com/EN/index.html
not one of their products cable / speakers
but their blog http://blog.apertura-audio.com/
said they they had a guest ...
And for this 2016 edition we won’t be alone ! Kostas Metaxas fromMetaxas & Sins will join us for unforgetable listening sessions.
He will present his brand new line of audio products: Ikarus, Solitaire and Opus. And more surprises also…
Ikarus Glittery Grey 056br        Red Solitaire 001
OK lets look at http://metaxas.com/
Bingo !
I'd love to hear some of the speakers some day.
Thanks for your Google-fu, Graham, I was too lazy to look.
The reason image-search came up blank is because an imaginary friend* of mine who went to the show took the picture, and took it at an angle to downplay its anthropomorphic qualities, I suspect on purpose.
33 minutes ago, spritzer said:
I'd love to hear some speakers some day.
Yeah, you should, speakers are cool.  Not as nice as headphones, but they're useful when you don't want to be tethered, or are moving around a lot, or have wet hair, or are dirty, or...
*Imaginary friend == anyone I've met online, but not necessarily in real life...
...wait, does that mean Jacob is my imaginary friend?
Yesterday finally acquired a pair of Equator audio Q12's. Yeah, I know - they're hardly audiophile with all their internal DSP trickery and 12'' drivers with compression horn tweeters are hardly appropriate for near field...
The Q12's are anything but mild mannered. Stock they go down to low forties/thirties and with my SB-2000 sub it's pretty much 20-20k coverage. And 500+200W continuos power is something to behold. Fortunately DSP tames the horn driver, so there's not really a hint of harshness.
Interestingly enough my SVS 12" sub has a hard time keeping up with the mains at high SPL's. The frenchman who sold me the Q12's has made me an extremely nice deal for the Equator Q18S sub. Think - 18", 1000W continuos and 16Hz -6dB point for a 160lb sealed box. On top of that I can daisy chain the sub to mains with a CAT5 cable and control all speakers via software.
And yeah - the photo is super dark, because that made my room look less untidy.
The info on the sub is scarce. At first I thought that Equator guys were crazy enough to devise 18" coax main monitors. Here's the skinny -
Frequency Response (-6dB): 15Hz - 180Hz
Recommended Line Level Input: 10mV-2V
Amplifier Power (LF): 1000W
Amplifier Peak Power (LF): 2000W
Sensitivity: 1w/1m output, 103dB
Max SPL: ≥129
Input Impedance: 10kΩ
L.F. Driver VC Size: 4”
L.F. Driver (4- ohm): 18”
Crossover Frquency: Software Configurable
Inputs: XLR, USB, RS485 in/thru, ¼” phone jack
Protection: Compression (LF), thermal, short circuit, under voltage
Magnetic Shielding: No
Enclosure alignment: Bass-reflex
Enclosure Construction: 1” HDF baffle & 3/4” 13 layer Baltic Birch
Finish: Black/Micro-Metallic Gray
Dimensions H x W x D (in.): 29 x 25 x 25
Shipping Weight (lbs.): 160
Originally these sold for around 5k$, but now I'm able to get one for 800EUR shipped.
So I sold a small Chipamp to a nice gent on Audio Asylum.  He was using it for (one of) his horn systems, and he said it worked out real well.  He sent me some pics of two of his other speaker systems:
Edited by skullguise
Wow!  I really like the big wood horn speakers.
Edited by chinsettawong
