August 16, 201115 yr comment_464367 Assuming somebody knows something just based on their education isn't a very good way to go. Take my EE Phd. cousin who had no idea how a dynamic speaker worked... That said, somebody with DIY experience should have no problem doing this. Report
August 16, 201115 yr comment_464387 That's something even I know! And I know next to nothing about the technicalities of audio! Well, he did build himself a pair of speakers so I reckon he does have DIY skills of some sort, although I don't know about more elaborate electronics, which I think is the case with an energizer. Well, I'll check it out with him anyways, but even if he happens to have no clue about the issue I'm sure I'll be fine since I dont regularly listen to loud music. Thanks again, Birgir! Report
August 16, 201115 yr comment_464415 Assuming somebody knows something just based on their education isn't a very good way to go. Take my EE Phd. cousin who had no idea how a dynamic speaker worked... This is hilarious! To be fair though, the deeper you go in a given field the more focused you get and the more you loose ground on reality... That doesn't mean you should forget the basis though . On a similar level, I've met bright technicians and terrible PhD (not meaning your cousin does not earn his PhD ... unless he's the same person who confused the K-1000 with an ES can over at HF in the sr-009 thread from Jude, lol ) Report
September 5, 201115 yr comment_468149 I feel like sticking up for the sometimes maligned SR-007MK2 (2.5 actually - the SZ3 series). Having lived with it for a couple of years more or less, I have found it ideal for my needs. It does not have perfect frequency balance, as has often been pointed out. But it is very, very good and has all the other sonic virtues of TOTL electrostatic headphones. Where it excels beyond other high end phones, for my old ears at least, is its forgiving nature. It brings out the best in everything rather than accentuating faults. Give it a crappy recording, within reason, and it sound as good as can possibly sound. Give it better material and it rises to the occasion. I am not aware of any other high end phone that sounds this good and is also completely forgiving of less than perfect recordings. I have a feeling that it was a deliberate balance of compromises, not a botched reworking of an almost perfect design. I will follow with interest the 009 to see where it fits in re: forgiving nature. I know it must sound great, but if it is not forgiving I may not have much use for it. I listen to a lot of music, and I can't put up with my gear dictating what I listen to. The music is the whole point, not the equipment. Almost unrelated, the SR-007MK2 is the most comfortable phone I have ever worn. I guess I have a Japanese head, size and shape wise. Report
September 7, 201115 yr comment_468438 Is there any way to source these? I believe my squealing SR007 need new drivers and I'm too afraid to send the pair to yamas. I fear they'll just put on mk2 drivers, charge me a whole bunch of money, and you'll all have to witness a grown man crying. As for the SR-007 drivers, it's just one of these things that I get offered from random people. Odds are though that replacements would be Mk2 parts which sound like poo... From yamas: "There is only 1 driver for both MK1 and MK2 and cost is approx. $1800." Anyone have some lube? Apparently replacing the drivers on my mk1 to make it an ugly mk2 will cost more than buying another mk1. Edited September 7, 201115 yr by DouglasQuaid Report
September 7, 201115 yr comment_468511 Yeah, there is a reason why I can't stand Yama's... If you do end up with another Mk1 I'd be willing to buy the squealing set off you. One can never have too many spare parts... Report
October 7, 201115 yr comment_473348 I've been testing out some theories with my SR-007's recently and it is quite clear that the odd sound of the SZ3 versions is all due to the drivers. I just swapped some late Mk1 drivers into my Mk2 set and the sound is completely different. Gone is the hard, forward edge of the SZ3 and this one sounds just like my Mk1. I decided to make the comparison fair so the port is plugged but only Mk2 parts were used aside from the drivers. I wouldn't recommend the driver swap since I had to modify the drivers a little bit and there are no spares anywhere if one messes up... The shape of the Mk1 drivers is also just a little bit different so they don't rotate as freely as they should. Small issue for me and some might even welcome it. Report
October 11, 201115 yr comment_473909 I've been testing out some theories with my SR-007's recently and it is quite clear that the odd sound of the SZ3 versions is all due to the drivers. I just swapped some late Mk1 drivers into my Mk2 set and the sound is completely different. Gone is the hard, forward edge of the SZ3 and this one sounds just like my Mk1. I decided to make the comparison fair so the port is plugged but only Mk2 parts were used aside from the drivers. I wouldn't recommend the driver swap since I had to modify the drivers a little bit and there are no spares anywhere if one messes up... The shape of the Mk1 drivers is also just a little bit different so they don't rotate as freely as they should. Small issue for me and some might even welcome it. What was the effect of the driver swap alone? Did it give a Mk,1 or Mk2 sound? If you change both the port and the driver at the same time you can't say how much is due to one or the other? Report
October 11, 201114 yr comment_473940 The effect of the port is well documented so that isn't really an issue. I also manipulate the arcs so that the port isn't a big deal even without it being sealed. The end result of Mk1 drivers in a Mk2 frame is just a Mk1 with more pronounced bass. That being the effect of the deeper earpads. Report
October 13, 201114 yr comment_474339 http://www.ippinkan....-009_sr-007.htm Japanese comparison of the two Airbow Lambdas + SR007A and SR009, probably full of bs based on the given points, why not compare against the normal Lambdas instead... Edited October 13, 201114 yr by padam Report
October 13, 201114 yr comment_474353 Well it's posted on Ippinkan which are the sole retailer of Airbow so you can draw your own conclusions. The SR-SC1 is a lovely headphone but better than a 007A... ehhh nope... Report
October 14, 201114 yr comment_474576 Assuming somebody knows something just based on their education isn't a very good way to go. Take my EE Phd. cousin who had no idea how a dynamic speaker worked... That said, somebody with DIY experience should have no problem doing this. The effect of the port is well documented so that isn't really an issue. I also manipulate the arcs so that the port isn't a big deal even without it being sealed. The end result of Mk1 drivers in a Mk2 frame is just a Mk1 with more pronounced bass. That being the effect of the deeper earpads. I think your cousin would understand that to detremine the effect of a variable you must change only one thing at a time It's sometimes called isolating a variable. In this case you have confounded your variables such that you can't say what part of what you hear is due to the contribution of the port or of the driver. Now you say the sound with the replacement driver is not actually the same as the Mk1 and you add yet another explanatory factor, the ear-pad which I must assume is the Mk2 pad.. I think the bass boost is caused by your sealing the port. I have sealed the port of my 007A and it didn't just give a "more pronounced bass" it gave a huge bass boost. So it may be that the Mk1 replacement driver could even have less bass in the Mk2 case. However there is nothing to be gained by speculation when it is easy enough to test by unplugging the port. Report
October 14, 201114 yr comment_474583 If I were you I'd stop making assumptions since you are clearly just talking out of your ass. Report
October 15, 201114 yr comment_474605 It seems Spritzer just isolated that variable rather handily. Report
October 15, 201114 yr comment_474625 I have no patience for condescension . One thumb down in the Head-Case Colosseum from me. Report
November 4, 201114 yr comment_478711 I read a post elsewhere that mentioned "obvious" quality control differences between O2 mk1s. I have not noticed such differences. Has anyone else experienced this? Report
November 4, 201114 yr comment_478721 The Omega has sounded amazing to me every time I've heard it. Report
November 4, 201114 yr comment_478722 I read a post elsewhere that mentioned "obvious" quality control differences between O2 mk1s. I have not noticed such differences. Has anyone else experienced this? Obvious -- no.. possible.. maybe Report
November 4, 201114 yr comment_478785 The SR-Omega is yummy but one can only wonder what it would sound like if Stax spent more then 10000Yen on the bloody chassis. Ohhh and add SR-009 earpads... I guess I need to start to learn Autocad. Just picked up the SR-X Mk3 PRO up from an extended loan and bloody hell these are amazing headphones. I've got to compare them side by side against the HP-2's but I think the Stax easily wins that comparison. I read a post elsewhere that mentioned "obvious" quality control differences between O2 mk1s. I have not noticed such differences. Has anyone else experienced this? I've owned more than most and they are all pretty much identical. Stax did change out some materials during the 9 year production run so early earpads and headpads are a bit different and the driver frame was changed as well but these a minor alterations. The sound is pretty much the same on all sets as long as you provide a level playing field by using the same earpads, similar arc's etc. There are some slight differences between driver sets but nothing to get worried about. I'd chalk this up as obvious BS... Report
November 13, 201114 yr comment_480308 Recently I grabbed an O2Mk1 and I need to get the headpad replaced. Is it physically the same as the MK2/A or does it need to be the old model one ? Report
