The Ultimate DIY Part 2 ? The KGITSOJC
What if the remote controlled a servo that that rotated the pot?
At least for me, it's just easier to go along with what the majority want to do. Panel wise and stuff it sorts out a lot of the headaches.
  • Replies 350
  • Views 133.4k
  • kevin gilmore
    kevin gilmore
    Sure there is a schematic. Its in my head somewhere. There will be an official schematic at some point. There is a bunch of different ways to build it including single ended only, and balanced/sin
  • Has there been any work on this lately?  I really want to do this one.
  • Input JFETs just came in the mail. Most of them look real, there are a couple 2sk170s that have funky looking printing on them that I'm not sure about. Will measure IDSS later.    Finally the projec
I'm a great believer in more-is-less.
That is why (some) classical recordings from the 1950's are so terrific - a couple of stereo pair mikes, two or three triodes, straight into a reel to reel. Eg Mercury Living Presence's 1812 and Beethoven's Wellington's Victory. Or the similar era Berlioz Symphonie Fantastique recorded in Walthamstow town hall with Barbirolli and the LPO in 1962. Or a staggering Der Rosenkavalier with Schwarzkopf in 1956 on EMI (stereo pair for the orchestra, a pair for the orchestra and a pair for the choir). Knocks many modern versions that go through a room-wide mixing desk and umpteen amplification stages into a cocked hat.
So if a digital remote of whatever flavour screws the sound up, lets have a knob.
The TKD 2500's are available with a motor... :)
i'll simplify it since you still arent getting the picture; hint 1 device = many remotes. I never said anything about having the dac functions on the amp.......
my journey from the bus stop is
1 listening to my portable dac/amp/JH13 via USB (camera connection)
2 I round the corner and pick up my hub, wake mac from sleep
3 check volume on (or choose) my transport in audio midi setup panel (RME PCI interface feeding BNC, AES or, M2TECH USB)
4 select playlist in itunes as if I was there
5 hit play
6 walk through the door to the music I just selected
7 open mail
8 relax on the deck, sipping single malt, listening to tunes and checking email
*volume will be controlled directly with ackodac uC as soon as the API is finished
and again, it doesnt have to be an ipad, just seems the logical choice (FOR ME) I get the idea of a cool hefty dedicated remote to match the superb chassis, but I have enough of them and I personally like having it all on the one device much more, so was just a suggestion.
BTW I used to run high resolution (>10000dpi) drum scanners in a pre-press house for my job and photographic compositing (in photoshop) freelance for many years after that; I have a pretty good idea what high resolution looks like. my guess is you were using iphone apps on the ipad early in the piece before native apps were the norm.
but no more OT, its clear you are anti idevices and thats cool; therefore this conversation is not only off topic, but not going to go anywhere.
i'll go back to watching these sexy amps take shape from the sidelines and look forward to hearing Nattonrice's amp at the next Sydney meet.
good show chaps!! stay safe
Edited by qusp
shortened post
So here is my comment on remote controls, after 20 years of trying to find the perfect one.
The sony programmable, the pronto, the harmony, software for the palm, software for a few other things,
and lately a crestron system. Every single one of them has serious design flaws. While i don't like
a pile of remotes, i have yet to find a better alternative. I am still looking. None of the above seem
to do as well a job on any particular device, than the original device does. Not sure why.
The touch panel is also the display. The infrared control will be something with an absolutely standard
and easily duplicatable control structure. If the touch panel software is written right, and it will be,
the cpu that runs the thing goes to sleep unless there is something to do. Combined with latching
relays that don't require power to keep activated. So all the magic crap is deactivated while you
are listening to music. So i don't see how the cpu is going to cause any trouble.
It seems maybe we should start a remote control company. Have you tried the Nevos? The HT companies around here seem to really like them especially over the Prontos.
Good to know, thanks KG.
All in one devices, for the most part, are useless.
Edited by deepak
Excellent, I like the way you think. I was thinking aluminum remote too. One that would be a menace to hard wood floors, small children and pets.
edit: my Audio Space integrated has a really nice remote. I don't know if it's aluminum, but it's 2 pieces of heavy metal. We could probably find something similar from China.
I do too. I always liked the remote to Voltron's Onix player. I would want the titanium remote to have razor sharp edges too to punish those that don't accord it due respect when handling it.
DanC are you going all aluminum 2 box that is the question? Anything less will be disappointing ;)
The infrared control will be something with an absolutely standard and easily duplicatable control structure.
Combined with latching relays that don't require power to keep activated.
So all the magic crap is deactivated while you are listening to music.
Reformatted to make the beautiful beautiful poetry more obvious.
The remote should be an IR laser gun. Instead of a button, have an IR receiver on the front panel for each function. You have to hit the target in order to activate each function.
The maximum? If it was cheap and feasible I wouldn't mind if the whole front panel was a screen.
Seriously wrong form factor for that kind of thing.
And it certainly is not cheap either.
Now if i was going to turn it into a home theater controller, and do 8 channels of balanced...
Then a 24 inch 16x9 panel would be about the right size.
What is the size of the psaudio... About 3.5 to 4 inches
ok, I'm assuming that's diagonal. Lots of options in that range.
Will people be buying multiple back ups of the touch screen? If it were to fail in the distant future I could see it being a pain to replace.
As with everything else in this fucked up world of ours, continuing availibility of repair parts in the future is a real problem.
For that reason i did not go with the 4D systems oled, which has already been end of lifed. What i need to do is find a display
device that is in massive use to guarantee lots of replacement parts.
Some kind of cellphone touch screen, perhaps?
Both the PSP and iPhone screens are cheap and easy to get ahold of...
  • 3 months later...
Sorry for butting in like this, but while admiring the work I couldn't help but pity anyone with less than stellar internet speed trying to download those monstrous board layout images.
Here's a 4000x3400 512kb GIF
And a yellow one, just because.
