February 19, 201412 yr comment_624120 Well there are some small issues. The KGSSHV logo is in the wrong spot so the screw is where the lower part of the K should be, one line is missing from the volume control bar and on the back the amp, the lines around the input section intersect with the screws a bit. I'll make another one though which will have this stuff fixed as this one has already found a home. I might get one of my Blue Hawaii's back then... Ordered some resin impregnated and fully shielded transformers so we'll see how that turns out. Ca. 110VA so plenty of current on tap. Report
February 19, 201412 yr comment_624141 You need to do small runs of these Spritzer. Who wouldn't want a compact, but high end stat amp made by the don himself? I'd certainly be interested. Report
February 19, 201412 yr comment_624144 You need to do small runs of these Spritzer. Who wouldn't want a compact, but high end stat amp made by the don himself? I'd certainly be interested. I'd be in for a pair! Report
February 19, 201412 yr comment_624146 We'll see how well the prototype runs and if I'm happy I'll probably make a few more as I have the PCB's. Also technically you need two fuse ratings listed Nahh, just stick a 6.3A in there Single Power style... Report
February 19, 201412 yr comment_624193 what kind of temps are you expecting? the heat sinks on the original, suggested dissipante case are definitely overkill Report
February 20, 201412 yr comment_624259 Not sure to be honest. Haven't even fired up the boards yet. Report
February 21, 201412 yr comment_624398 What I'm really looking forward to is another one of these chassis that I have here. The reason is simple, the sinks on that one are huge so hello MOAR current. Even though the HV circuit is extremely linear with regards to output stage bias it doesn't hurt to run it far harder. That may remove some of that high end grain that is evidently very clear with the 007Mk1... Report
February 21, 201412 yr comment_624400 Yes good work Birgir a great idea to do the small alternative. Since I posted here in late 2012 I have had a "year of the Stax" and would like to feed back what I have built. First KGSShv (an on-board) powered a pair of SR-507 I had. I have since designed and built a more compact off-board. Several enthusiasts were interested so I intended to build them the same to simplify the design effort. They were to be black cases with silver knobs and the controls operating the pot and switch at the back. However people have their own wants so I ended up customising the original to build several versions. The most radical mods were an all silver amplifier with polished front panel and top, with a different layout of a large centrally mounted attenuator, and a rather subtle look. The third request was for a modified “standard” design with two Stax sockets and if possible the large attenuator, which was squeezed in. I have done another design for a more compact “Cube” and then I will have done all I can think of for now at least. We rate the A_D 41 step attenuator as a worthy companion to Dr Gilmore’s circuit – only time will tell if it proves reliable but it seems well made. Thank you to Justin and Birgir along the way and the advice from Kevin. Without Kevin Gilmore we’d be nowhere. http://headinclouds.imgur.com/all/ Report
February 21, 201412 yr comment_624405 Yes thank you - so do I. It is the prettiest I've built and I had to be persuaded to make the effort to research the metal finishing etc. The buyer suggested the A_D attenuator and the overall approach to the layout and finish. Report
February 22, 201412 yr comment_624611 Great work Spritzer - really like the compact design Speaking of offboards... As some of you might have spotted, I quite like to push the envelope in making smaller and smaller amps. Going with what Kerry did but in an off the shelf chassis and no SMD parts it is a challenge to shrink something this complicated. PSU isn't ready yet but it is version of the BH design so +/-400V max. That does mean more current though... The chassis is about 10mm wider than a SRM-727, similar height but much shorter. Ohh and far more power... Also, one should never do the chassis artwork 1 hour after they should have gone to bed... Report
February 24, 201412 yr comment_624842 The Silver one is reminiscent of the Sony SCD-1. Awesome looking chassis! Report
February 24, 201412 yr comment_624853 Very nice work hics. Thank you - It was a lot of effort but they turned out well. I know they sound great but I wanted them to look not too DIY as well. I used the Modushop case for my first ones and it is very easy that way, but for my own design there was no need to go abroad. I live just outside the West Midlands which has a metalworking tradition going back hundreds of years. It is only a short drive to the suppliers of the heatsinks, aluminium, laser cutting, machining, finishing, printing and engraving. Being able to meet and discuss the work, particularly for the finishing has been a great help and much more interesting. Report
February 24, 201412 yr comment_624860 Those builds look great. I love that you have access to metalworking shops. For me it is all sourced or made myself. Fun, but not easy - especially for the finishes. Report
February 24, 201412 yr comment_624862 This is exactly my problem too, nobody around to do any of this for me. Report
February 24, 201412 yr comment_624864 Yes hats off to you Kerry - oh Birgir's popped up in the last few seconds! and you Birgir for the fantastic work you do in house. Report
February 25, 201412 yr comment_625083 I'm in the middle of the KGSSHV build, my first electrostatic headphone amp. I have a question: how do I make a dummy load for the amp? do I need one for the initial adjustment? Thanks Report
