digital attenuator
  • Replies 415
  • Views 137k
  • I've got my controller boards working pretty well now with the digital attenuators.  I like the larger one because it has a really nice feel as you turn the volume knob (...yes I see it ). I went
  • Here's the code.  Just rename the PDF to Zip and expand it into a folder under your .../Documents/Arduino directory. The code works well now, though there are a few things I'd like to keep workin
  • Just wanted to offer a quick update on this...... I couldn't get the "all in one" code from @Kerry to work perfectly with my setup; it always opened up the relays to full volume on power-up, and I cou
will we get better result when using vishay resistors rated at .01% (some of them are 5 ppm, seems be the king)?
You'll get a tighter match to the ideal resistance curve of the attenuator. Whether it will be audible or not, doubtful. 0.1% should be good enough.
Some might say using the naked Vishay s102/z102 would be the best (and most expensive), but I don't think these are available in surface mount.
On 2016/5/16 at 9:59 AM, luvdunhill said:
It's more important to use E96 series resistors than the tolerance levels.
Wow, why E96 is the key?
Closest to the ideal values probably?
//UFN
Exactly. I suppose you could parallel each position and calculate closest parallel equivalent, but yes - this is more important than 0.01% because in fact a 1% might randomly get you closer to then ideal value.
  • 10 months later...
I've got my controller boards working pretty well now with the digital attenuators.  I like the larger one because it has a really nice feel as you turn the volume knob (...yes I see it :P).
I went and added a USB input to the board itself, though this is really overkill - which is why I did it.
Here I'm updated with the TX / RX LEDs blinking away.
IMG_0313.thumb.JPG.f843a2dd0446734d726b1df0d22eb590.JPGIMG_0314.thumb.JPG.49108924af68518ce41335f0f66addb4.JPG
EDIT: I've got to do one more round of cleaning...
Edited by Kerry
The code works well now, though there are a few things I'd like to keep working on.  It will drive one of the I2C 1" OLED displays.  I typically comment this out at line 101 in the main program (EDIT since I don't use the display in the amp)...
  //  If not using display just don't create it
  activeOLED = new OLED (128, 64,SSD1306);                                                        // I2C Display
  //activeOLED = new OLED (128, 64,SH1106, OLED_MOSI, OLED_CLK, OLED_DC, OLED_RESET, OLED_CS);      // 1.3" SPI Display
I'm happy to keep working on it.  I can post the Gerber files as well at some point.
VolumeController.pdf        ->  rename to VolumeController.zip
EDIT:  I just wanted to add a note that this will work on an Arduino UNO or Pro Mini.  Pretty much anything with an Atmel 328P.  Could probably support other chips as well.
EDIT 2: This code will run the older and larger I2C boards (requires a slight code change) as well as version .4 and .5 of the current SPI boards.
Edited by Kerry
  • 4 months later...
Hi guys
Does someone have boards that don't need and can sell it to me?
They can be only the pcb and also can be already populated.
Thanks for the help
That is just all kinds of cool!
7 hours ago, ti5002000 said:
Hi guys
Thanks for the help
I think I have a couple boards I could sell you.  Send me a PM.
On 8/14/2017 at 7:11 AM, ti5002000 said:
Hi guys
Thanks for the help
You can check with @sorenb
  • 1 year later...
On 7/23/2015 at 10:59 PM, kevin gilmore said:
for the V2 attenuator, there was one missing wire, will fix soon.
fixed
http://gilmore.chem.northwestern.edu/boards/attenuatorsmtv2.zip
http://gilmore.chem.northwestern.edu/attenuatorsmtv2.pdf
i have a question. i have tried to get quote for this board, and when i have uploaded the gerber file, system detected 3 layers. i can choose between 2, 4, 6. if i were to use 2, what happens if this inner layer is discarded? or in case of 4 layer, i suppose this inner layer is then duplicated and then there are two 2-layer boards pressed together with same inner layer?
thank you
Did anyone ever put this together with the selector boards that were run?  I was looking at AMB's setup for volume and selecting sources but I seem to remember somebody saying that his attenuator won't work with the amps here.  It would be cool to put this together with the SE/BAL to BAL/SE board
I got a set of two boards I’m planning to build soon - too many projects but this has come back on the radar
Anyone still have boards?
Decided I'd like to give this a try if I can get my hands on the boards.
Randy
If you can't find spare boards then you could just add a 4th layer (like just duplicate the middle layer) then you could get new boards made quickly and cheaply at a place like https://oshpark.com
Otherwise 3 layer is less commonly available and you might have to go to a more expensive PCB manufacturer.
