Stax Teflon Jacks - More of them
Here is what I think will work for pricing
1-2: $20/ea
3-4: $18/ea
5-9: $17/ea
10+: $16/ea
*add $5 per normal bias jack (go ahead and combine pro/normal jacks in your total count)
+ 3% paypal & shipping
I'm assuming that shipping weight will be below 1lb for all but the largest quantities, so expect about $6 USA and $25 international
subject to change because I havent been given the final costs yet
  • Replies 154
  • Views 47.6k
  • I am in for at least two normal and two pro to add to the collection. Hopefully my dreams of an unused diy parts based economy comes to fruition someday soon.
That is really reasonable. Are you going to include pins, or would that be an add on?
My experience has been that the correct hole diameter is completely dependent on the pin. I have 3-4 different types of pins. Some fit perfectly in the jacks, and some are super tight. You may already be thinking this, but I would make sure you purchase a ton of the same type of pin and tweak the hole size as necessary to get your preferred fit. I like my jacks to be snug but I don't like to fight the jack when inserting the headphone connector.
Maybe you need lube? Oh, and Justin has already said on the previous page that pins come preinstalled. I trust he will get it right.
1-2: $20/ea
3-4: $18/ea
5-9: $17/ea
10+: $16/ea
So for 4 jacks, two normal two pro it would be 4*18 plus 2*5 = 82 plus PP and shipping. Yeah, I can dig that.
I'm in for 4 pro, thanks.
what i think might work best is to load the pins onto a Stax plug, then insert it into the connector shell, then tighten the nuts. i'll suggest this to the machine shop
I'm still up for at least 10 (I said a dozen in my previous post). I know at least one other person here who wants to built a 'stat amp or amps so I'll get some for them.
Samples have been made, and are on the way to me now
Is there a reason why you don't make the jacks in black teflon given that the chassis is most often black?
I was told that black teflon has impurities in it that won't like high voltages.
I think the ones in that picture are CMC bakelite tube sockets?
Audio Note calls them black teflon:
Along with all this, our latest version of the Interstage MonoBlocks includes a stunning new set of solid copper Insert Plates and black Teflon valve bases now standard with both our single and parallel configurations!
Not sure since i've never seen an audio note up close, but the voltages are
about half that of electrostatics. Its unlikely to actually be black teflon.
I did test black delrin, and it starts conducting at about 200 volts.
All of the connex octal sockets are white teflon. Probably for a reason.
If its bakelite, then that is a different story. Not sure what the real stax
jacks or the amphenol jacks are made of. I can probably test an amphenol
jack, but i'm likely not to have the time to do that for a few months.
surprising about black delrin since that's what the eric343 HE60 sockets were made out of several years ago
hey i should get some of those made…
Very nice! How snug is the fit with the stax connector?
Edited by Horio
