The Multi Amp aka Dynalo Mk2
Hi Kevin:
Is it possible to make the filter and bypass capacitors also SMD?  The finished board would have a really low profile and can be stacked together and still fit into a slim case.
Edited by mwl168
  • Replies 1.6k
  • Views 520.3k
  • johnwmclean
    johnwmclean
Does it support TO92L? I'm wondering what the holes are by the transistors.
SMD components are so sexy!
the holes are feedthru to the other side. the to92 are not the same pinout and those holes are
very tiny and masked.
could do the caps as surface mount, pick a package.
the pots would end up the tallest item.
Did some search on Mouser. SMD film caps seem quite expensive and not that small in size.
Maybe use polymer filter capacitors and stick with through-hole film bypass capacitors?
One set is two boards ?
I'm in for a balanced dynalo.
Copied.
I'll order the through-hole version as I still have some MPSA/MPSW
Edited by G600
I was awake and I missed it.  :(  There'll be another.
I do have 2 sets of the original boards with the mpsw parts if anyone is interested.
also 2 sets of the unbal to bal boards, also with the mpsw parts.
That's exactly my kind of insanity :D
In case anyone still wants Dynalo boards, I have one set left. It's the slightly older MPSW/MPSA version that requires the simple capacitor grounding jumper fix that Kevin pointed out a couple of pages upthread. (I also have several extra protect3 boards.)
I've double checked 2^3 times, Digikey delivered me 31 out of 32 20ohm vishay CMF50s.
The frustration is so real.
Edited by lkong
I would have gone with the resistors I used for the 20 ohm, but that should work fine.
pretty quick assembly.
Oh, please stay away from Canare Star-Quad. Very high capacitance. The so-called advantages of the twisted starquad are offset by its disadvantages. I suggest Mogami cable designated for AES/EBU, but it's really very low capacitance balanced cable great for analog: http://www.mogamicable.com/category/bulk/dig_interface/aes_ebu/
It's very neutral, no sonic color, very wide bandwidth. The only down side of the Mogami is you have to be very fast on the soldering iron because the insulation melts very quickly. But then, good soldering technique is a badge of being a DIYer.
I've got another section of Canare L4E6S ordered so I can wire up a balanced cable. Single ended it sounds pretty good with LCD2, maybe seems a bit bright. I'll need to double blind with the KSA5 to see if it's just me. I'll take your advice and swap to balanced input at some point.
Switch is from ebay here: http://www.ebay.com/itm/151028998690
Jumpers? I added two for the sense right at the unit....is there one that comes off? Voltage is a little low, 13.3 is what I'm getting out of it now.
I'd be in for a 4deck 10K if the price is reasonable.
Ordered off board version of golden reference boards from seeedstudio 1.6mm 2oz copper
Will have some extras for grab when my order gets here.
I love those boards!
Thanks
so you have heard of book matched veniers...
well...
http://gilmore.chem.northwestern.edu/dynalobal16.jpg
Very nice, any possibility of adding thru hole pads for the output stage emitter resistors ?
I am thinking about using Vishay TX2575 Z-Foil resistors (0.15"/3.81mm leadspacing)
Texas Components lists the ASM2575 SMD version but they seem to have trouble getting the substrates for the small (0805, 1206) sizes.
Happened to me the last couple of times when I tried to place an order for them.
