The Multi Amp aka Dynalo Mk2
  • Replies 1.6k
  • Views 538.2k
  • johnwmclean
    johnwmclean
I had some comments back so I've made the following changes:
  • I reversed the SE and balanced outputs
  • I fixed a mistake in the schematic for the negative off-board voltage regulator
Thanks to Kevin (of course), Birgir, Marshall and Joachim for your feedback :D
Here's what might be the final...
Edited by Kerry
Error on one of the pics
This is a good reason to get back into dynamics, awesome work Kerry.
Alpha will only do a 1000 pc order last time I checked.
We'll have to look into options.  I've sent the board out to manufacturing so we can prototype it :D
I want 2 of 'em.    Well, just because.........    :wub:
maybe i just got a bad batch, but i had a lot of trouble with the Alpha pots and plan to stop offering it in the GS-X mk2. A large percentage of them have a noticeable lump at a particular point when turning it. Sometimes you have to have a large knob attached first and then turn it slowly to find the spot. but around half of them ended up in the trash
It must have been a bad batch as these work perfectly.  Some of my first ones had the center bump but I returned all of them.
1 hour ago, kevin gilmore said:
fine, cram the new digital attenuator in there. should be enough room.
That would be wonderful!
SMD, SMPS... Blasphemy!
I'm actually super proud to see HC finally embracing the newer tech. How do these SMPS'es look under the scope? Does extra after-regulation help?
Edited by RudeWolf
Not going to be easy. I started thinking about it. A couple of daughter boards might do the trick. It would be nice to have a modular solution.
Very cool Kerry! Subscribed!
Very nice board layout as well. What did you use for that?
Thanks.
The design was done in DipTrace v3.  I've been using it for a while and like it.
