The Multi Amp aka Dynalo Mk2
should I socket the LED's?  I remember doing this on my original Dynahi to get the offset as low as possible.
Here's the latest with LED and cap changes
Dynalo MkII Rev 1.2.xls
Edited by sbelyo
  • Replies 1.6k
  • Views 549.6k
  • johnwmclean
    johnwmclean
Not needed here because the offset is trimmable here - it wasn't on the original Dynalo.
  • 4 weeks later...
My dynalo mini started acting up. Balanced output works fine, but SE output had low volume and distortion.
I did another thorough clean up with alcool, double checked everywhere for solder bridges and it started working again, probably some bridge of flux I didn't spot before.
It now has almost even level between channels, but just a bit lower level on the left channel. It could almost be due to a potentiometer inbalance but it is perfect in balanced output.
 Dc is 0.1-0.2 on the right channel and 2.4-2.6 on the left. When starting up the bias goes down quickly on the right channel but take a bit longer on the left one. this is with servos in the circuit path. I took VDC measurements around the board on most transistors and servo opamps and I couldn't spot any differences between the 4 channels.
Any ideas of what might be causing this? Thank in advance for your help!
I assume that the values shown are mV? Also, when you say bias, I assume you mean offset?
The first place I would start would be to measure the bias voltage across all of the 20R resistors, noting any variances. I would then do a comparison of the biasing circuits (consult the schematic) and go from there. It can be difficult to spot solder bridges on these, so checking resistance across all resistors (power off) might show you something. I know I had a resistor shorted that looked fine.
Edited by Pars
Those are dc offset mV indeed. long day yesterday...
I'll take readings on the resistors and check the biasing circuits to start!
So I found a dead resistor in the R+ channel and replaced it. The L+ channel is the one acting up.
I removed the servo jumpers and dialed the offset to less than 5mV on each channel. All fine. When I reinstalled the jumpers the L+ dc offset jumped to around 350mV while all the other channels remain below 2-3mV (but still wondering between 0 and 2-3mV, not ultra stable).
The servo opamp for the L+ channel is getting power as it should. Might the IC be damaged and causing this?
On further inspection, the 100k resistor next to the opamp measures 28K when soldered (I removed it and it measures 100k as it should)
The opamp is measuring 1.1ohm between pins 2 and 3 (input + and input-) this is different from all the other opamps so I'm ordering a new one.
Edited by MASantos
Does anybody see an issue using MMBTA56LT1G/MMBTA06LT1G now that MMBTA56/MMBTA06 are obsolete?
I replaced the opamp and now it reads as the other 3. The offset still drifts around below 10mV. All other amplifiers I built (cfa, ckk3) with dc servos were very steady once the servos were installed.
Is this drifting normal in the dynalo mini? I can't seem to find any solder bridges, it is as if the servos are not doing their job at all.
Sound is now centered and similar in both SE and BAL ouputs, it is just the drifting that is puzzling me.
Edited by MASantos
John, those should be fine. Comparing the datasheets, it appears that thermal performance has decreased ( or been reevaluated), but electrically the same.
Regarding the Dynalo, yes, they do seem to drift more (and act like the servo isn't working). IIRC, even the full size ones do this.
I can confirm that the full-size SuSy Dynalo offset does drift even with servo engaged as Chris stated.
My own observation:
1. The drift is mostly ambient temperature related. A cased amp drift less than a free-standing (aka air-chassis) amp does
2. The + out and - out drift the same amount so, while the offset relative to ground drifts, the voltage difference between + out and - out are fairly stable
Edited by mwl168
  • 2 months later...
On 12/13/2020 at 10:50 PM, Youwin0125 said:
Please help to upload the file again.
The web connection of file is loss.
Thanks a lot ^^
Hi Youwin0125
I'm also new to the forum and with KG's help I found the share drive below with all the gerber files:
** LINK REMOVED ** GILMORE CAN POST IT IF HE WANTS **
There are a ton of Dynalo zips in there... no clue which is the latest and greatest! 😕
kgdynalobal9 was the one I used for the group buy a few years back.  As far as I know there were several built.  Not sure what 9g and 9g2 are.
Hi! i would like to share my work with you. I made an dynalo amp powered by grlv power supply and a pcm1794a/cm6631a dac. Everything is totaly made by me. I also designed the pcb nd ordered it from JLCPCB. Amp offset voltage stays at max +-1mV and it is totally silent. Case is DOUK AUDIO.
pictures:
https://drive.google.com/drive/folders/1a6cbGFpN6s5EadR8DA_lb21ZFwOwzK4R?usp=sharing
Looks neat. Looks like you didn't go for a balanced output on the Dynalo, any reason?
biggest reason is cost. i am a student so cost is a problem. second reason, i wanted a somewhat small and compact all in one. maybe in the future i will make a balanced version
I see now that I missed it - I thought you built a SUSY Dynalo and only used one phase of the balanced output. I see now it's actually a single-ended Dynalo. Did you follow Kevin's original Dynalo schematic from many years ago?
Edited by mwl168
yes. it is an old jfet input dynalo. i was lucky to get matched jfet pairs, but they were expensive. i followed the old schematic with tht components, but made some modifications because i used smd components. and my version has slightly more power. power supply is not modded, equivalent smd components are available
and i want to ask you something. is there much benefit to using balanced output? lets say i will use this amp only with sennheiser hd650 and it has enough power to drive it and it is completely silent.
The balanced amp gives twice the voltage swing and slew rate and 4 times the output power. Wether that matters for a headphone like HD650 is debatable. My personal opinion is yes.
The motto here at HC is "moar is better" and never pass a chance to go overkill >:D
Edited by mwl168
thank you for your response. maybe i will have the chance to build one someday
Very nice headphone amplifier indeed.
Please don’t wait too long with your next project. We want more.
i would like to build it, but i am a student so cost is a big problem unfortunately
can i maybe replace the jfets on original dynalo with that340? and what mods should i do? i think i must tune the ccs, and change pot from 50k to 10k. correct me if i am wrong
Hi All,
After reading this entire thread, it seems there are a number of options for transistors to use in place of THAT340 on the input stage (if you can source them).
Please could someone help rank the below in order of preference?
- 2SJ109 / 2SK389 appear impossible to source
- LSJ109 / LSK389 (LSJ109 also looks hopeless unless you roll the dice on ebay / aliexpress)
- 2x Matched pairs of LSJ74 and LSK170
- 2SC3381 / 2SA1349
- LSK489 / LSJ689
- Anything else?
Or just go with THAT340 and live with the low input impedance that seems to be a minor issue?
Thanks!
