AOIP (Audio over Ethernet) or is USB dead?
5 hours ago, astrostar59 said:
I am done.....
If I had a nickel for every time I heard this...
What's wrong with listening to you?  You haven't established any credence yet, that's what.  If I tried everything that some random stranger on the internet told me to try, I wouldn't have time for the things that I truly enjoy.  And I'd have a buttload of Galaxy Note 7s.
I've already explained why you shouldn't be the one pushing this.  If you persist in ignoring me and in your unpaid shilling, I shall have to resort to stronger words.
  • Replies 51
  • Views 14.8k
  • Craig Sawyers
    Craig Sawyers
    Some interesting details of getting an SPDIF interface to work properly are here http://www.audiocircle.com/index.php?topic=45330.0 Although, even if you get the data transmission perfect with SP
  • stand by this.
  • Dusty Chalk
    Dusty Chalk
    If I had a nickel for every time I heard this... What's wrong with listening to you?  You haven't established any credence yet, that's what.  If I tried everything that some random stranger on th
Bah, just use a DAC which has a memory buffer and galvanic isolation. It will sound the same with any input, because jitter will be dictated by the on-board master clock and galvanic isolation will take care of most of the ground/line crud.
The only price to pay for this would be latency induced by buffer size. Mine adds 0.5ms.
You can't just go spewing out stuff like "USB is dead, because my AOIP gear makes me feel better/different".
P.S. Just keep in mind guys, that USB audio can't really be compared to other data transfer protocols which have error correction. USB audio can't do checksums and repeat sends, it'll just cut out, if the stream gets interrupted. In theory you could make an audio transfer protocol which would have a buffer and then attempt resends for bad packages until the buffer runs out. Think - anti-vibration systems on those portable CDPS your cool friends had.
12 hours ago, astrostar59 said:
Ok so put your head in the sand,
Sand has some positive effects on jitter, transparency and bass resolution, in case you don't know. Try it. Really. I'm not kidding. But beware; sand must come from ocean beach.
I read somewhere that wasn't the case. You'd get a bad value. Then that was supposedly poo-poo-ed because if you got an error on the most significant bit, the sonic world would end and everybody would hear it.
The poo-poo-ing made me very suspicious, because an error on the MSB would be a lot like a zero-crossing error. I've made, well, a few zero-cross errors in editing and nobody ever noticed. But I suspect that one every hundred thousand samples or million samples or so would probably sound like bad sounding digital.
All of which suggests to me exactly what you said: Buffer enough to be able to resend resend packets. Why not?
Forget the techno, just get to hear it. Simple.
On 11/10/2016 at 11:46 PM, astrostar59 said:
I am done.....
done with what?
Fucking idiots are never done being fucking idiots.  You're just repeating yourself now.  At this point you sound like you're arguing even if you're not, unless you change your tactic.
Hear it then:
Ahh yes, the age old "I don't have any leg to stand on, no actual knowledge of the matter but I'm delusional enough to think I'm right so the beautiful, beautiful music will tell all" argument.  Classic...
Image result for pig with lipstick picture
  • grawk unlocked this topic
But but but...
On 11/6/2016 at 5:58 AM, grawk said:
I think the super audio best friends or whatever they're called is where you want to hold that particular debate, thanks.
Fine, but if he keeps repeating himself, I'm banning him.
I guess I found something exactly same with what is he doing (yea I like Family Guy):
just where does that device fit in the chain?
4 hours ago, grawk said:
oh, this is definitely not the right place for the debate.  It is the right place for abusing an idiot.  Don't ban him, harrass him.
Really? We learned nothing from Trump? Don't fucking enable him.
