Flight Case?
  • Replies 100
  • Views 23.7k
Oh man, I think I just posted the most bought deal to date! I think the competition is the battery charging thingy.
I bought two as well - I don't even know for what I'm going to use them. :palm:
x2 (meaning I bought 4 and don't even know what I am going to use them for :palm: :palm:)
I decided to get one too and I don't know what I'll use it for either, since it's not big enough for any of my headphones - unless maybe I got a Grado again....
I decided not to go through with my order after all. I was going to order from work but then I remembered all the crazy security the bank has, so I had decided to postpone it till I got home. Well, once I got home, I started thinking about what I could actually use this for, and came up empty.
So I decided to pass the offer. Instead, I figured I might buy some more music, which is always good.
I bought one too. Anyone have any suggestions as to how to neatly trim the foam inserts to fit a pair of headphones so the inserts look like they came from the HP manufacturer? I tried trimming the foam in one of my pistol cases a few years ago using a single edge razor and a ruler and the result was very nasty looking.
Considering they are a bunch of small diced shaped foam blocks that you pick out, it would be hard trimming each tiny block and then reassembling.
I bought two for my Stax or Grado this summer.
I plan to use it with my RS-1, and maybe my K1000 if they will fit (to spare the wood box when transporting them). Hence I ordered two. My HD600 should be too deep to fit, as are my D2000.
I'm upset I didn't get one of those cases despite the fact that I don't need it.
Also, for those of you interested in Pelican cases, but unsure of sizing, I recommend the following free thingy: PelicanOEM.com - Free 3D Case Fitter
You're from NYC right? I ordered 6 and 2 are called for by my friends, so... I think we can work something out.
Has anyone recieved their flight case yet? Mine should arrive tomorrow.
