What sort of size on the adapter? When I made ones for octals I would just buy tube bases and epoxy a socket into the top of it.
  • Replies 1.5k
  • Views 427.9k
  • Craig Sawyers
    Craig Sawyers
I was just looking to make a plug and play solid state replacement for an octal tube so the idea is a little PCB with an octal tube footprint on it and then just solder in the tube pins
Oh, that's pretty nifty sounding. It'd probably still be easier to use a normal octal tube base and stuff the PCB on/in it. Just a board with pins sticking out might be pretty hard to get out of a socket once its in, without something else to grab onto for leverage.
6 hours ago, mypasswordis said:
...And do you know where I can buy tube pins to make an adapter? I'm not trying to Singlepower tube roll, I promise.
Try this one on eBay, I've bought them and they work very well.
http://www.ebay.com/itm/100pc-CMC-8P-Tube-Socket-Gold-Plated-Pin-Hex-Snap-2x10mm-Hole/130342225019?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2055119.m1438.l2649
I believe that's for the socket side, a female pin, and what MPI is trying to do he wants male pins.
33 minutes ago, mwl168 said:
I believe those are pins for the actual tube sockets, and I actually have some of those already. But what I am looking for is the pins that you would find on a tube that plugs into the sockets.
Did some ebay searching for tube bases like Fitz said.. something like this maybe? http://www.ebay.com/itm/161158036593 Then I would still need pins to solder the PCB to the tube base pins. It could potentialy work but is quite contrived, maybe there's a better option...
Edit: what she said ^
Edited by mypasswordis
Dunno if they would have anything, but you might look thru MillMax's catalog.
Thanks, you're a wizard! Found this: 3121-2-00-15-00-00-08-0
Need to make sure the diameters are all okay before I order
Midway through heat gunning some SMD components the station straight up died. No lights or anything. I opened it up and am measuring nothing across the transformer primaries even though I checked the power switch and fuse are working. Never had this happen before. Wut do?
Never seen that happen.  Was it one of those cheapo hot air systems?
who made the thing, and inside pictures please.
likely the thermal fuse inside the transformer went open, may be able to short it out.
I got this cheap junk: http://www.ebay.com/itm/3-in-1-853D-SMD-DC-Power-Supply-Hot-Air-Iron-Gun-Rework-Soldering-Station-Welder-/381253195679?hash=item58c476179f:g:XAcAAOSwImRYWK8A It actually looks fairly okay on the inside (see pics below) but I tried locating a thermal fuse on the transformer and wasn't sure where to look. There does seem to be a PLUS version with a case fan, which does seem indicative.
Can't use camera right now (long story) but here are some pics which are basically what mine looks like on the inside:
http://voltaicforge.com/electronics/wep-853d-clone-soldering-station/
and the transformer looks like this:
Is Conrad Heatsinks out of business? I've sent them an email about the mf35-75 3 weeks ago with no answer :(.
It's probably still around, but I've never received a reply to any email I sent that way. I don't think it's interested in business coming through email.
Not sure what dimensions you're looking for, but Fischer Elektronik makes excellent heatsinks in various sizes. They're somewhat available at various places (I've had intermittent luck with finding stock at Newark Electronics and TME, https://www.tme.eu/en/).
Edited by gepardcv
I got an order from them (Conrad) about 2 months ago.  Communications is a bit spotty, but they are there still.
Edited by Kerry
It looked like they have an online order form. Shipping to the US (or not Aus) looked like they have to contact you with the amount. Did you try that route?
I wrote an email with the sinks / qty I wanted.  They got back to me within about three weeks with quotes including shipping.  Once I sent payment, they shipped almost immediately.
I had some follow-up questions after I got the original quote that went unanswered.
I tried to fill the form but got a 404 error. I copied the order and sent it to them via email. Awfully silent. I hope they answer me one day, I am almost finished with my full custom carbon case.
I also asked them what the fillet applied to the fins is. To me it looks like a 2mm tangent fillet. Since they will unlikely ignore my question, can someone measure the fillet?
If I go the route of ordering the heatsink as a custom part as well, will a cnc shop be able to make a heatsink? E.g. a winged one like on the diyT2 and bhse?
Horizontally mounted fins hinder proper natural convection so it's a bad idea for a Carbon.
Bad in not optimal or bad in frying transistors?
Does anyone know where I can source pentaconn sockets? Either chassis or PCB mount.
Thanks. I checked Mouser and Digikey and they both have TRRRS connectors, but none that are 4.4mm. Maybe I just need to wait for Neutrik to start making them.
