July 29, 201115 yr They sound best with a blue hawaii besides, this is head-case, not "save me from buying shit case"
July 29, 201115 yr Don't have a BH. Don't need the headphones. Money better left in the bank. Just bought an SR-003 anyway. I give myself 2 days.
July 30, 201115 yr I thought they sounded fantastic from Marc's hot rodded KGSS. Now my hot rodded KGSS.
July 30, 201115 yr I can't remember if I owned two or three pairs. But I agree with Deepak. The high-pitched squeal always happened at least intermittently. I always had to short the pins eventually to try removing it for a listening session. I wouldn't even consider a pair if overseas without that warranty to lean on.
July 30, 201115 yr Koss servicing in europe means sending things to Switzerland i think. I hadn't realised that the squeal issue was so prevelant though.
July 30, 201115 yr "Agreed (couldn't stand that wall of sound, with no space). And every pair I owned eventually developed the high frequency squeal." "I love the ESP950, among my favorite headphones." Proof of the mnemonic "YMMV"....
July 30, 201115 yr The squealing issue could be due to the practically unprotected drivers. Koss did make reservations for a voltage divider in the amp to cut the bias supply so this makes it a more likely cause. I've been itching to get a ESP950 and fit the drivers in the HE90 frame I have here. Groupbuy?
July 30, 201115 yr How about you give me some measurements and I custom make the drivers for you to try? Wachara C.
July 30, 201115 yr Now that would be a brilliant idea. I would also be open for some machined adapter plates so I can try my collection of Lambda drivers in those frames.
August 14, 201115 yr Guys, I'm not sure whether I should post this in here or in the amp section, but as I don't want to open a new thread for this, here it goes: Which one do you think would be best for an O2 MKI, a modded 727A or a 323S? Will they be a significant upgrade over my SS eXStatA? Edited August 14, 201115 yr by Leonardo Drummond
August 14, 201115 yr Yes it certainly would I would go no less than a modded 727A. I don't know if I get flamed for that but on today's micro meet I was shocked by a power cable change on the 717, it was much better sounding than it was before. Apart from the bass which I find hard to get accustomed to it was quite stunning.
August 15, 201115 yr Thanks for the help, Padam (not the first time you helped me, eh?)! It's quite hard to find the mod instructions, do you know where I can find it? I've got no DIY skills yet so I'd ask a friend of mine who's an engineer to do the mod for me, but because of that, it would be great to have all the information and all the detailed steps needed to do it!
August 15, 201115 yr Does not look hard to do, should only take a few minutes. It is possible that you take out the sockets and send them to someone who does the mod, and put them back - if you don't need to re-set the voltage which is a little trickier (or you just use a step up transformer). Because it is probably in Japan where you can probably find one the quickest. Edited August 15, 201115 yr by padam
August 15, 201115 yr Thanks again, Padam! Fortunately as I buy a lot of equipment from the UK, I have 220V and 110V sockets in my bedroom, so either a US or a japanese unit will be fine! Now I just have to go find a used 727A.
August 15, 201115 yr There is no way to just modify the boards and slip them into a factory spec amp as it has to be adjusted for offset and balance. Get that wrong and the servo shuts off the output.
August 16, 201114 yr That's better then! Thanks, Birgir. I usually don't listen to music very loud, so I suppose that won't be much of a problem. By the way, is that something an electronic engineer would know how to do easily?
