March 6, 201214 yr comment_502099 Someone left it behind. I believe it was used as a shroud to hide his ManDate magazine. Report
March 6, 201214 yr comment_502106 "Now if somebody can spot my way of dealing with the 10M90 sinks with only metric screws at hand... " That's what I did. I later thought I could have drilled a hole and tapped it M3 a little higher up the heatsink, but thought the loss of mounting surface on the device would be overly compromised. Report
March 7, 201214 yr comment_502170 Nice looking build I'm all about smaller these days so love that it fit it a 2U case. Report
March 7, 201214 yr comment_502203 When I test the 4686 transistors I get an unexpected reading using my DMM and only with the transistors in the middle (red arrows, and on both boards): Collector to emitter: 0.75 V On the rest of the 4686's: OL Both base-collector and collector-emitter conduct one way only as expected. Why do I get those readings only with the middle ones and not the rest? both boards? At first I thought they were damaged but its to much of a coincidence with the same ones on both boards. Report
March 7, 201214 yr Author comment_502233 Those are the top output transistors, and you can't measure them in circuit that way and get reliable results. Report
March 7, 201214 yr comment_502256 Thanks. I figured it was because they were in circuit, but wasn't sure why. Report
March 7, 201214 yr comment_502314 Measuring anything while in circuit is always a crapshoot. Way too many variables to list. While we are on the subject, the HV sounds fucking amazing!! Who stuck a subwoofer to my 007 Mk1's? Report
March 7, 201214 yr Author comment_502320 Yeah Team. Boards at the post office , will pick up tomorrow. prototypes of the multiamp,blackhole and preamp. Will be sending justin his knob tomorrow also, i had better see pictures of it mounted. Edited March 7, 201214 yr by kevin gilmore Report
March 7, 201214 yr comment_502337 Will be sending justin his knob tomorrow also, i had better see pictures of it mounted. Damn! At least make it a challenge for me Kevin! Report
March 8, 201214 yr Author comment_502358 Sorry, i'm tired and could not be much more creative. Report
March 8, 201214 yr comment_502372 No, waiting for the transformer. Will be drilling holes in the heatsink on friday. Edited March 8, 201214 yr by eggil Report
March 8, 201214 yr comment_502443 eggil - I’m just curious for my own understanding, wouldn’t soldering those transistors last be preferable? Report
March 8, 201214 yr comment_502452 I see what you mean, but what I am doing is not that hard. I have not screwed the aluminum plate to the transistors yet. Report
March 8, 201214 yr comment_502471 Good luck drilling, I look forward to seeing your amp eggil. Edited March 8, 201214 yr by johnwmclean Report
March 9, 201214 yr comment_502678 Actually it will be only 1. I had 2 in the picture to help me figure out where to drill the holes. Report
March 10, 201214 yr comment_502881 Well, drilling the heatsinks was harder than I thought! Hope didn't screw up anything. Edited March 10, 201214 yr by eggil Report
March 11, 201214 yr comment_503105 It looks like the same guy who started this train-wreck of a thead over there is actually going forward with his build. Report
March 11, 201214 yr comment_503106 thats the same guy!? hope he at least figures out how to wire a transformer before it arrives... Edited March 11, 201214 yr by El_Doug Report
March 11, 201214 yr comment_503138 Why are people using CMF60 resistors for the bias ballast? Doesn't anybody read the bloody spec sheets? Report
March 11, 201214 yr comment_503153 I suppose because theyre prettier, and that several companies have made it seem like the Vishay/Dale name automatically makes things better. "So what if theyre only rated for a 500v maximum? Theyre cool!!!" Why are people using CMF60 resistors for the bias ballast? Doesn't anybody read the bloody spec sheets? Report
March 11, 201214 yr comment_503173 Yeah that plus people not knowing what they are doing. Vishay is basically an umbrella for everything now but they do own BC (aka Philips) so that opens up a lot of good stuff. These are the ones I use: http://www.mouser.co...XoJNmZF%2flI%3d Edited March 11, 201214 yr by spritzer Report
