March 6, 201214 yr Someone left it behind. I believe it was used as a shroud to hide his ManDate magazine.
March 6, 201214 yr "Now if somebody can spot my way of dealing with the 10M90 sinks with only metric screws at hand... " That's what I did. I later thought I could have drilled a hole and tapped it M3 a little higher up the heatsink, but thought the loss of mounting surface on the device would be overly compromised.
March 7, 201214 yr Nice looking build I'm all about smaller these days so love that it fit it a 2U case.
March 7, 201214 yr When I test the 4686 transistors I get an unexpected reading using my DMM and only with the transistors in the middle (red arrows, and on both boards): Collector to emitter: 0.75 V On the rest of the 4686's: OL Both base-collector and collector-emitter conduct one way only as expected. Why do I get those readings only with the middle ones and not the rest? both boards? At first I thought they were damaged but its to much of a coincidence with the same ones on both boards.
March 7, 201214 yr Author Those are the top output transistors, and you can't measure them in circuit that way and get reliable results.
March 7, 201214 yr Measuring anything while in circuit is always a crapshoot. Way too many variables to list. While we are on the subject, the HV sounds fucking amazing!! Who stuck a subwoofer to my 007 Mk1's?
March 7, 201214 yr Author Yeah Team. Boards at the post office , will pick up tomorrow. prototypes of the multiamp,blackhole and preamp. Will be sending justin his knob tomorrow also, i had better see pictures of it mounted. Edited March 7, 201214 yr by kevin gilmore
March 7, 201214 yr Will be sending justin his knob tomorrow also, i had better see pictures of it mounted. Damn! At least make it a challenge for me Kevin!
March 8, 201214 yr No, waiting for the transformer. Will be drilling holes in the heatsink on friday. Edited March 8, 201214 yr by eggil
March 8, 201214 yr eggil - I’m just curious for my own understanding, wouldn’t soldering those transistors last be preferable?
March 8, 201214 yr I see what you mean, but what I am doing is not that hard. I have not screwed the aluminum plate to the transistors yet.
March 8, 201214 yr Good luck drilling, I look forward to seeing your amp eggil. Edited March 8, 201214 yr by johnwmclean
March 9, 201214 yr Actually it will be only 1. I had 2 in the picture to help me figure out where to drill the holes.
March 10, 201214 yr Well, drilling the heatsinks was harder than I thought! Hope didn't screw up anything. Edited March 10, 201214 yr by eggil
March 11, 201214 yr It looks like the same guy who started this train-wreck of a thead over there is actually going forward with his build.
March 11, 201214 yr thats the same guy!? hope he at least figures out how to wire a transformer before it arrives... Edited March 11, 201214 yr by El_Doug
March 11, 201214 yr Why are people using CMF60 resistors for the bias ballast? Doesn't anybody read the bloody spec sheets?
March 11, 201214 yr I suppose because theyre prettier, and that several companies have made it seem like the Vishay/Dale name automatically makes things better. "So what if theyre only rated for a 500v maximum? Theyre cool!!!" Why are people using CMF60 resistors for the bias ballast? Doesn't anybody read the bloody spec sheets?
March 11, 201214 yr Yeah that plus people not knowing what they are doing. Vishay is basically an umbrella for everything now but they do own BC (aka Philips) so that opens up a lot of good stuff. These are the ones I use: http://www.mouser.co...XoJNmZF%2flI%3d Edited March 11, 201214 yr by spritzer
