December 7, 201411 yr A question for Kevin or Spritzer I read there was an extensive mod to the 727 that included boards out and transistor swops, and was set out by Kevin. Have you a link to the post please, I can't find it. Did it succeed in bringing the 727 close to a KGSShv i.e. a big jump in sound quality, or was it just bringing it closer to the older 717? Thanks in advance guys, I know you are busy on multiple projects! Go back to HF, we don't need your annoying bs here.
December 7, 201411 yr Now for something new as this one was just fired up: This was done as an exercise by me to see just how small we could make a stereo KGSSHV board and to do one that used only in production parts. On Semi had something to say about that though... A question for Kevin or Spritzer I read there was an extensive mod to the 727 that included boards out and transistor swops, and was set out by Kevin. Have you a link to the post please, I can't find it. Did it succeed in bringing the 727 close to a KGSShv i.e. a big jump in sound quality, or was it just bringing it closer to the older 717? Thanks in advance guys, I know you are busy on multiple projects! Please keep this stupidity on HF where it belongs. You don't have even the slightest clue what you are talking about.
December 7, 201411 yr Very neat! I am really in love with the small stereo board, but I should probably finish my "normal" KGSSHV first //UFN
December 7, 201411 yr Now for something new as this one was just fired up: This was done as an exercise by me to see just how small we could make a stereo KGSSHV board and to do one that used only in production parts. On Semi had something to say about that though... Please keep this stupidity on HF where it belongs. You don't have even the slightest clue what you are talking about. Sorry Spritzer, I didn't mean to offend. I read a post on head-fi and wanted to see if it existed anywhere in posts?: The mod n3rdling referenced was a mod Kevin Gilmore came up with. He himself has indicated it essentially turns the 727 into a lower powered KGSSHV.
December 7, 201411 yr I just remembered, I sent a guy I know in the UK over to you to buy one of your KGSShv's. I want to promote the DIY community, not wind folk up, and I have bought DIY stat gear and been on these forums a while. Pity I seem to get attacked (rather unfairly). I think I also offered to help you on your website for free, though you were covered anyway on that. I love this hobby, but don't understand the politics, maybe I will just bail.
December 8, 201411 yr there's no politics you're just being a dipshit about your likes and dislikes. nobody paid you to be a tool
December 8, 201411 yr Sorry Spritzer, I didn't mean to offend. I read a post on head-fi and wanted to see if it existed anywhere in posts?: The mod n3rdling referenced was a mod Kevin Gilmore came up with. He himself has indicated it essentially turns the 727 into a lower powered KGSSHV. Think it was either the 717 or 727 cannot remember off the top of my head can be modded to a 350v limited "low power" kgsshv. Antonyfist (Tony) was the first to mod his with helpful instructions on the procedure from K.G. You can PM him on head-fi or email him but he is not very active on that site. Edited December 8, 201411 yr by DefQon
December 8, 201411 yr Cool build. Have you managed to get it silent in the this version? Does the 2sc4686 still count as an in production part?
December 8, 201411 yr At least you can still buy lots of genuine c4686's at fairly cheap prices. Unlike a1968's.
December 8, 201411 yr Spritzer, one more question: I assume this means the Gerbers posted for the KGSSHVstereo are fine as-is and no changes are required? //UFN
December 8, 201411 yr Cool build. Have you managed to get it silent in the this version? Does the 2sc4686 still count as an in production part? This build is meant to be +/-400V max so FJPF2145 works perfectly as the output device. Spritzer, one more question: I assume this means the Gerbers posted for the KGSSHVstereo are fine as-is and no changes are required? //UFN Kevin handles that side so I have no idea. Should be fine...
December 8, 201411 yr Very nice build! Which power supply board did you use? Something custom, or something available from KG's site?
December 9, 201411 yr It can be done, the circuit is certainly linear enough but the PSU is a problem. I could do a +/-250V that would run off 12VDC as I have the switchers for that.
December 20, 201411 yr Does anyone have CAD files of the front panel of the Pesante Dissipante 3U 400 with stax socket etc? It would save me a lot of time drawing the front if I had one. A CAD file of the whole Pesante Dissipante 3U 400 would be even better
December 20, 201411 yr I have 3U Pesante Dissipante drawn up. Depends which Stax socket your using though. My Drawing fits this Stax socket, for a 10mm front panel; Drawing; Pm me if you wan’t this drawing, John Edited December 20, 201411 yr by johnwmclean
January 1, 201511 yr Can anyone share PEEK m3 screws, washers and nuts? If not, then is there any interest if I order (probably 100) and share?
January 1, 201511 yr Hi. I was wondering what is the purpose of a balanced stereo pot (e.g. how are they different). I noticed some people use balanced stereo units like the ALPS RK27114, and a few have upgraded to the RK50 which is stereo. When selecting a pot or attenuator, how important is it to choose balanced stereo models? The inputs are XLR (if that makes a difference).
January 2, 201511 yr it depends on the design of the amp if you will require 1 or 2 sections per channel. the RK50 is available in 2 sections (stereo) or 4 (balanced stereo)
January 2, 201511 yr In the Stax 717 amp (and maybe others) there is a volume bypass control switch. Would turning a pot or stepped attenuator to the maximum achieve the same effect? I'm worried that turning the volume up will clip the amp.
January 6, 201511 yr In the Stax 717 amp (and maybe others) there is a volume bypass control switch. Would turning a pot or stepped attenuator to the maximum achieve the same effect? I'm worried that turning the volume up will clip the amp. I have the Stax 717. The volume pot bypass switch makes the 717 act like a power amplifier i.e. the output level is determined by the input signal from your source. Before setting the switch you MUST ensure you have a source that has a volume level control be it a PC output or a pre-amplifier. The input to the 717 should not exceed around 2 volts. If you try it and you have correct level listening at about 12 o'clock it is fine. The bypass does improve the SQ as it misses out the losses in the pot.
