digital attenuator
Here's the code I used for the rotary encoder and the Uno board:
#include "Wire.h"
// Set up the Variables
int state, prevstate = 0;
int nextEncoderState[4] = { 2, 0, 3, 1 }; int prevEncoderState[4] = { 1, 3, 0, 2 };
const byte attSetAddr = 0x38;
const byte attResetAddr = 0x3E;
const int offVolume = 100;
const int relayLatchTime = 3; // time in milliseconds
int newVol = offVolume ;
void setup() {
delay(1000);
Wire.beginTransmission(attResetAddr);
Wire.send(0);
Wire.send(0xFF);
Wire.endTransmission();
delay(relayLatchTime);
Wire.send(0);
Wire.send(0x00);
// Set up for the encoder
pinMode(5, INPUT);
pinMode(6, OUTPUT);
pinMode(7, INPUT);
digitalWrite(5, HIGH);
digitalWrite(6, LOW);
digitalWrite(7, HIGH);
void SetVolume(int newVol)
int sendVal;
// now set
sendVal = (byte)newVol ;
Wire.begin();
Wire.beginTransmission(attSetAddr);
Wire.send(0);
Wire.send(sendVal);
delay(relayLatchTime) ;
Wire.begin();
Wire.send(0);
Wire.send(0x00);
// now reset
sendVal = 0xFF ^ (byte)newVol;
Wire.send(0);
Wire.send(sendVal);
Wire.send(0);
Wire.send(0x00);
void loop() {
state = (digitalRead(7) << 1) | digitalRead(5);
if (state != prevstate) {
if (state == nextEncoderState[prevstate]) {
newVol = newVol + 1;
if (newVol > 255)
newVol = 255;
SetVolume(255-newVol);
} else if (state == prevEncoderState[prevstate]) {
newVol = newVol - 1;
if (newVol < offVolume)
newVol = offVolume;
prevstate = state;
EDIT:
Quick thanks to Max and the Arduino site where I got some of the code segments :)
Edited by Kerry
  • Replies 415
  • Views 139.1k
  • I've got my controller boards working pretty well now with the digital attenuators.  I like the larger one because it has a really nice feel as you turn the volume knob (...yes I see it ). I went
  • Here's the code.  Just rename the PDF to Zip and expand it into a folder under your .../Documents/Arduino directory. The code works well now, though there are a few things I'd like to keep workin
  • Just wanted to offer a quick update on this...... I couldn't get the "all in one" code from @Kerry to work perfectly with my setup; it always opened up the relays to full volume on power-up, and I cou
Has anyone ever tried interfacing a Krell CAST DAC or Audio-Gd ACSS DAC to a KGSS/KGSSHV amp, keeping the signal in the current domain? I would think that whatever you used for a volume control- be it pot, stepped attenuator, resistor/relay or IC switches would have less sonic impact in an ACSS circuit than using a voltage divider in a voltage-domain circuit..... and in using current domain signals you eliminate the I-to-V stage in the DAC, any stage eliminated is a stage that can't screw with the sound.
Too specific for most people. Besides which, cast does not really work the way
you might think it does. Raw current out of a dac is unusable with even a few
feet of cable, and then there are all the offsets that need to be controlled.
Yeah, you are right, for the ~7(?) DACs or analog preamps out there that have CAST or ACSS outputs, I guess developing a current domain input for the KGSS/KGSSHV would be a fair bit of work that would benefit very few users. While from all accounts it seems this signal transmission scheme does offer real sonic benefit, it is used by almost no one.
Got my boards as well!
Thanks for everything and looking forward to the KGITSOJC!
Get my boards today. Thanks Kerry for making this GB.
Could someone help me with how to use this thing?
Wachara C.
Just wanted to post where I'm at with testing/shipping. Here's everything shipped. I should have some time this weekend to get through some more testing.
Name - Assembled - Bare Boards - Shipped
Beefy - 0 - 4 - S
blubliss - 4 - 0 - S
cetoole - 0 - 10 - S
chinsettawong - 2 - 0 - S
deadlylover - 0 - 6 - S
deepak - 2 - 2 - S
DouglasQuaid - 2 - 2 - S
Fitz - 0 - 4 - S
Flyingsparks - 0 - 4 - S
Horio - 0 - 2 - S
johnwmclean - 0 - 2 - S
kevin gilmore - 4 - 4 - S
luvdunhill - 0 - 2 - S
nattonrice - 0 - 4 - S
Pars - 0 - 2 - S
Shaman - 0 - 2 - S
tcpoint - 0 - 2 - S
Vortex - 0 - 10 - S
Edited by Kerry
Here is code to control two attenuators (i.e. balanced) with a potentiometer. Wire pot pins 1 and 3 to 5v and ground, and the wiper to A0 (analog input 0). Should work for a single board as well. For balanced configuration jumper id pins 1 and 2 of the second board (to change the address). Based on the code previously posted by Kerry.
#include <Wire.h>
int sensorPin = A0; // select the input pin for the potentiometer
const byte attSetAddr0 = 0x38;
const byte attSetAddr1 = 0x39;
const byte attResetAddr0 = 0x3E;
const byte attResetAddr1 = 0x3F;
const int numReadings = 12; // max readings for averaging
const int maxVolVariation = 3; // max allowed variation in pot voltage without changing volume
int oldVol = 0;
int readings[numReadings]; // array to hold volumes (for averaging)
int readIdx = 0; // readings array index
void setup()
for (int i = 0; i < numReadings; ++i)
readings = GetVolumeSetting();
oldVol = GetVolumeSetting();
delay(1000);
void WireTrans(boolean begin, byte addr, int range)
if (begin)
Wire.begin();
Wire.beginTransmission(addr);
Wire.send(0);
Wire.send(range);
// comment out if volume control works in reverse
//newVol = 255 - newVol;
// put avg volume into newVol
readings[readIdx] = newVol;
readIdx += 1;
if (readIdx == numReadings)
readIdx = 0;
int total = 0;
total += readings;
newVol = total/numReadings;
// include only if relay chatter because of pot voltage variations
if (abs(newVol-oldVol) < maxVolVariation)
return;
oldVol = newVol;
// now set
int sendVal = (byte)newVol;
WireTrans(true, attSetAddr0, sendVal);
WireTrans(true, attSetAddr0, 0);
WireTrans(true, attSetAddr1, sendVal);
WireTrans(true, attSetAddr1, 0);
// now reset
WireTrans(false, attResetAddr0, sendVal);
WireTrans(false, attResetAddr0, 0);
WireTrans(false, attResetAddr1, sendVal);
WireTrans(false, attResetAddr1, 0);
int GetVolumeSetting()
// pot reading
int sensorValue = analogRead(sensorPin);
// convert to new range
sensorValue = map(sensorValue, 0, 1023, 0, 255);
return sensorValue;
void loop()
SetVolume(GetVolumeSetting());
delay(50);
Hope this helps,
Steve
Edited by stv1756
Here is working code for volume plus balance:
#include <Wire.h>
int sensorPinVol = A0; // select the input pin for the volume potentiometer
int sensorPinBal = A1; // select the input pin for the balance potentiometer
const int maxPotVariation = 4; // max allowed variation in pot voltage without changing volume
int currVol = 0;
int currBal = 0;
int volReadings[numReadings]; // array to hold volumes (for averaging)
int balReadings[numReadings]; // array to hold balances (for averaging)
int volReadIdx = 0; // readings array index for volume
int balReadIdx = 0; // readings array index for balance
void setup()
volReadings = GetVolumeSetting();
balReadings = GetBalanceSetting();
currVol = GetVolumeSetting();
currBal = GetBalanceSetting();
delay(1000);
boolean balChanged = SetCurrBalance(GetBalanceSetting());
volReadings[volReadIdx] = newVol;
volReadIdx += 1;
if (volReadIdx == numReadings)
volReadIdx = 0;
int total = 0;
total += volReadings;
if (abs(newVol-currVol) < maxPotVariation)
if (balChanged)
newVol = currVol;
else
return;
else
currVol = newVol;
int leftVol;
int rightVol;
if (currBal < 125)
leftVol = newVol;
rightVol = newVol*127/currBal;
if (rightVol > 255)
rightVol = 255;
else if (currBal > 130)
leftVol = newVol*127/(255-currBal);
rightVol = newVol;
if (leftVol > 255)
leftVol = 255;
else
leftVol = newVol;
rightVol = newVol;
// now set
int sendLeftVal = (byte)leftVol;
int sendRightVal = (byte)rightVol;
WireTrans(true, attSetAddr0, sendLeftVal);
WireTrans(true, attSetAddr1, sendRightVal);
// now reset
sendLeftVal = 0xFF ^ (byte)leftVol;
sendRightVal = 0xFF ^ (byte)rightVol;
WireTrans(false, attResetAddr0, sendLeftVal);
WireTrans(false, attResetAddr1, sendRightVal);
boolean SetCurrBalance(int newBal)
// put avg balance into newBal
balReadings[balReadIdx] = newBal;
balReadIdx += 1;
if (balReadIdx == numReadings)
balReadIdx = 0;
int total = 0;
total += balReadings;
newBal = total/numReadings;
if (abs(newBal-currBal) < maxPotVariation)
return false; // currBal remains the same
currBal = newBal;
return true;
if (begin)
Wire.begin();
Wire.send(0);
Wire.send(range);
// pot reading
int sensorValue = analogRead(sensorPinVol);
return sensorValue;
int GetBalanceSetting()
// pot reading
int sensorValue = analogRead(sensorPinBal);
sensorValue = map(sensorValue, 0, 1023, 255, 0);
return sensorValue;
void loop()
delay(75);
BTW, these attenuators sound fantastic. Many thanks to Dr. Gilmore and Kerry!
Steve
I've got just about everything shipped. Two more to go, which I'll get out early next week.
I wanted to beat the hurricane before Manhattan floats away :D
thanks a bundle!
Here's the list of what is shipped:
Beefy - 0 - 4
blubliss - 4 - 0
cetoole - 0 - 10
deadlylover - 0 - 6
deepak - 2 - 2
Driftwood - 4 - 6
dwhat - 4 - 0
el_doug - 2 - 0
Fing - 2 - 0
Fitz - 0 - 4
guzziguy - 2 - 0
Horio - 0 - 2
Jezz - 2 - 2
jgazal - 2 - 0
johnwmclean - 0 - 2
Kerry - 2 - 10
luvdunhill - 0 - 2
manaox2 - 2 - 0
MASantos - 2 - 2
Max - 1 - 0
minivan - 2 - 0
n3rdling - 4 - 0
nattonrice - 0 - 4
Nebby - 4 - 0
Pars - 0 - 2
Samuel - 2 - 0
Shaman - 0 - 2
tcpoint - 0 - 2
Vortex - 0 - 10
EDIT:
Got the last two out as well:
spritzer - 4 - 0
ujamerstand - 4 - 0
Edited by Kerry
They came today and look great! Thanks Kerry and Kevin Gilmore!
Was there a BOM posted? I looked thru the thread, but may have missed it.
Link to the BOM:
here
It's hard to find all the resistor values from the same manufacturer. I also couldn't find 2 values in the appropriate package or in small quantities. Manufacturers are mixed and matched right now, but all of them are ±100ppm/°C, 1% 1W thick film resistors. Also need the value for the compensation caps. If anyone wants to edit or have it in a excel file let me know.
I used the IRC thin film with .1% tolerance.
Here's the actual values and part numbers.
RP7 15 PFC-W1206R-03-15R0-B
RP6 619 PFC-W1206LF-03-6190-B
RP5 4530 PFC-W1206LF-03-4531-B
RP4 15800 PFC-W1206LF-03-1582-B
RP3 41200 PFC-W1206LF-03-4222-B
RP2 93100 PFC-W1206LF-03-9312-B
RP1 196000 PFC-W1206LF-03-2003-B
RP0 402000 PFC-W1206LF-03-4023-B
RS0 1330 PFC-W1206LF-03-1331-B
RS1 2610 PFC-W1206LF-03-2611-B
RS2 4910 PFC-W1206LF-03-4991-B
RS3 8870 PFC-W1206LF-03-8661-B
RS4 14300 PFC-W1206LF-03-1372-B
RS5 20000 PFC-W1206LF-03-2002-B
RS6 23200 PFC-W1206LF-03-2322-B
RS7 23700 PFC-W1206LF-03-2372-B
RT 24300 PFC-W1206LF-03-2432-B
edited according ujamerstand
Edited by jgazal
That one is a little outdated. There are newer resistor values a couple pages back. (24.3k impedance vs. 10k in the older BOM, I think?)
Here's the actual BOM I used to order:
Quantity Ref Def Item Description Mouser Digikey
2 PCF8574AN 595-PCF8574AN 296-13106-5-ND
2 ULN2803AN 595-ULN2803AN 296-19046-5-ND
8 G6SK-2F-DC12 653-G6SK-2F-DC12 Z2666-ND
1 ID 1x3 Pin Header - .1" 571-5-146276-3
1 Mini Jumper 151-8010-E
2 Terminal block 651-1935190
2 PCF8574AN DIP-16 Socket 4816-3004-CP
Resistors
2 3.3K Resistor Pack 71-CSC09A01-3.3K
2 Pullup 3.3K Pullup Resistors CRCW12063K30FKEA
Input Z = 24K
Qty, Ref, Value, Part #
2 RP7 15 PFC-W1206R-03-15R0-B
2 RP6 619 PFC-W1206LF-03-6190-B
2 RP5 4530 PFC-W1206LF-03-4531-B
2 RP4 15800 PFC-W1206LF-03-1582-B
2 RP3 41200 PFC-W1206LF-03-4222-B
2 RP2 93100 PFC-W1206LF-03-9312-B
2 RP1 196000 PFC-W1206LF-03-2003-B
2 RP0 402000 PFC-W1206LF-03-4023-B
2 RS0 1330 PFC-W1206LF-03-1331-B
2 RS1 2610 PFC-W1206LF-03-2611-B
2 RS2 4910 PFC-W1206LF-03-4991-B
2 RS3 8870 PFC-W1206LF-03-8661-B
2 RS4 14300 PFC-W1206LF-03-1372-B
2 RS5 20000 PFC-W1206LF-03-2002-B
2 RS6 23200 PFC-W1206LF-03-2322-B
2 RS7 23700 PFC-W1206LF-03-2372-B
2 RT 24300 PFC-W1206LF-03-2432-B
Capacitors
2 100uF 661-EKZE250ELL101MH0
EDIT:
The three pin header was a bit tall and I had to trim it down.
Edited by Kerry
