DIY cable gallery
  • Replies 606
  • Views 269k
  • Harvested an old Cardas Headphone cable to make a balanced cable for the HD800. Neutrik 4-pin XLR connectors. The HD800 connectors are from Parts Connecxion and a royal PITA to work with.
  • luvdunhill
    luvdunhill
    Even scarier
  • I made some cotton sleeved speaker cables - going to get them hooked up to my horns which I moved my rack over to the side and as such needed two different length cables… couldn’t find any coconu
TONIGHT, WE 5-PIN DIN IN HELL!
So that's what the back looks like. :palm: Not my usual plug and play toy but it is surely ready to kick some azzzzz. Oh, Mac mini in da house.........
That's a sexy-ass cable right there, and it will work great, but why isn't he using the multi-pin DB25 or whatever it's called connector next to the TRSs?
He will, of course, as evidenced by the cable I posted on the previous page. ;) And the reasoning for this set is easy, like if you got to a meet and don't want to drag the full octopus DB25 cable (which is what it'll eventually be). There are also still lingering questions about what outputs are available to the firewire input. The TRS connections are CH1 and CH2 only so the hope is that they will be the easiest to setup and get him up and running.
I obviously didn't look back, but I thought you had done the DB25, which led to the science/madness/sparta jag. Yeah, the full octopus is quite something. I think the setup I sent to Greg will give him the same output in L/R pairs across the 8 channels, so Ch1 and Ch2 will definitely work as a start. Here's what my octo-outputs looks like:
balanced TRS to balanced XLR, obviously :)
Obviously! Ugly fucking thing.
looks good nate, and avoids perhaps the most hideous looking audio connector I've ever seen:
But those are good for removing ear wax!
My what big ears you have.
What's a DB-25 connector? I thought those ports were to connect my printer to the ULN-8 when I wanted to print copies of the cue sheets. :P
The TRS to XLR cable will serve multiple purposes; as Nate stated, they can serve as traveling and meet cables, they can serve as primary cables while I am fiddling around with/searching for additional XLR to whatever cables, and lastly they may very well serve as my preamp to mono block interconnects.
"Cat o' nine tails" except it's 8.
I have unofficially named them the Nugget Audio Octo Udders.
