January 14, 201412 yr This could be end up being a nice solution for some. http://store.acousticsounds.com/d/94817/Sony-USB_Hi-Res_DAC_System-DA_Converter_or_Processor
January 14, 201412 yr from my five minutes of shitty googling: pcm1795 lm2876 chipamps 4580 opamps (for what I'm not sure, I/V duty?) It seems like a solid set of parts for an all-in-one. Can't see much else so I don't know if there's a separate headphone amplifier.
January 14, 201412 yr I liked the Wadia PowerDAC that I had, similar type of unit. This seems to take it a step further with the DSD input, plus line in & out....
January 14, 201412 yr No, it's not too late. If you continue to post inane shit, I'm sure changstar would be glad to have you as a member, but you'll be done here.
January 14, 201412 yr I think he's talking about the fan on the back panel. Although I am now so thoroughly entertained by the peanut gallery's contributions that I almost didn't say anything. Sent from mah phone-blet via Tapatalk
January 14, 201412 yr Well it is sort of a valid point, the dust buildup will be substantial. It's quite busy in there, must be an EMI nightmare. On a related note, for those with a bigger budget, I found this in the related images search - http://www.amazon.com/Sony-HAPZ1ES-Hi-Res-Player-System/dp/B00FFZD29Q Internals Seems like it might be a more compelling unit in some of your audiotistic setups. If you were anal about fans I could imagine some bullshitting with an SSD and/or heatsink would go a long way in this unit. Edited January 14, 201412 yr by nopants
January 15, 201412 yr No, it's not too late. If you continue to post inane shit, I'm sure changstar would be glad to have you as a member, but you'll be done here. I indeed was just talking about that fan, if you misunderstood and were insulted in some way my apologies. But yeah the thing i don't like about fans mostly is the smaller they are the more annoying the noise is. Even more so if it starts to wear out or has to spin too fast. And indeed the dust is an issue as well, judging by the label the fan is set to suck air out of the case which creates negative air pressure which in turn makes the case a giant dust magnet. Maybe it only spins at a certain power output but i doubt it given how busy it is inside that case.
January 15, 201412 yr Well they did make that SCD-XA777ES, was it? That Justin favors so much. So maybe we should disconnect the fan and put in some passive cooling, and/or recase it with a larger quieter specialized fan before we give up on it. And by we, I mean one of you DIY guys.
January 15, 201412 yr EMI filter cores? Hmm hopefully nothing like the badly designed SACD series Sony had back in the day that all had grounding issues with the PCB's. Sweet looking 1TB music player though.
January 16, 201412 yr Not a problem, that kind of distortion is undetectable if one is listening with Beats.
January 16, 201412 yr or drunk. or doing whatever that takes your attention elsewhere. No one listens to the music anymore.
January 17, 201412 yr I do. Especially when I'm drunk. That's a tweak, man. It does iOS and Android, I wonder if it does linux. That's one thing I miss about this HRT, it stops working every time I switch over to linux.
