Head Case Motorsports
#1 gets my vote with #3 second. The color looks most correct in 1 and at least when viewed on my iPad has the best dynamic range. With 3 I feel like the image is significantly underexposed.
Sent from my iPad using Tapatalk
  • Replies 2.1k
  • Views 370k
  • First day in two months the high has been below 55 and first day in almost 3 its snowed.  Hopefully this bad luck isn't a sign of how things will go with the new toy i just took delivery of..
  • I learned a ton and had a blast at my Driver's Academy class on Saturday. There were 24 students, about 16 of the 24 were teens and young-twenty-somethings and the other 8 of us were older drivers. Fo
How about this then.
I like the revised #3,
I think I would take it in a Cayman or a 911 form.
The revised #3 seems too washed out, but that is a problem of I'd like to see a less brightened revision of no. 3, but Jeff may not have all night to fuck with this.
The solid headlight trails in #3 are a little off putting. The broken trails in #1 are more visually pleasing to me. Everything else can probably be fixed in post.
The underexposure can be fixed in the post easily enough, as the new version of #3 shows.  I liked the traffic pattern in the background the best, in #3.
This, I liked 3rd for the background pattern more than the color in the car.
This. I would have liked something closer to the first #3, but then again, I would rather have seen the driver side of the car for this shot. I can't place just why at this moment, but I think it'd work better in that frame.
**BRENT**
Cameron's C&C
Sweet Classics
Germans
Americans
Exotics
What the hell is the point of popping the hood if you don't remove the plastic engine cover?
The engines are back behind those shrouds.  They were fairly visible.
Those Javelins are under appreciated.  Would love to do a restomod of one or the coke bottle shaped ones like Donohue raced in the Trans-Am series.
Great pics.
HS
The wheels on that Yellow Fauxbra are fugly as hell!
Great pics.
HS
If you're referring to the Blue AMC car, that is not a Javelin, but an AMX.
Edited by swt61
I'm gonna take this back....you are correct.  It's an AMX.  Thanks for clarifying.
HS
Edited by HemiSam
It had a 347 V8
It had a 347 V8
Interesting.  Maybe a bored 343??  I'm no expert.  I'll defer to swt61.  I know my MOPAR's better.
HS
The 347 was sourced from Ford.
Okay, I decided last nights pics all sucked so I went back out around sundown for some more.  Any of these look worthwhile?
