KGSSHV Carbon Build Thread
11 minutes ago, Sebtdi said:
I got mine on Ebay and they were authentic Cree's 170D. Nothing blew up in smoke and sounds great
Can you post the sellers name? Thx.
On 7/22/2021 at 4:14 PM, chinsettawong said:
This is my version - 3D printed using ABS filament.
Nice work!
Could you post or link the source file for the 3D printer. Thx.
  • Replies 2.1k
  • Views 694.3k
  • johnwmclean
    johnwmclean
    Finally done! I regrettably sold my previous KGSSHV Carbon a while ago, this one’s not going anywhere soon. This is a 400V, 19mA version, using the ground plane amp board, Sumr transformer a
  • My own Carbon, not going anywhere... IMG_6585 IMG_6590 IMG_6592 IMG_6593 IMG_6595 IMG_6596 IMG_6597
I hope chinsettawong will not mind me posting this link to the 3D file.
https://www.tinkercad.com/things/7pGkeN939L6
Thanks guys for the quick response, but I would prefer getting my Crees from a source I can trust.
BTW, those parts from an Ebay link do look fake, I red through this entire thread and have seen pics of the real deal.
Replace with 1200V Cree's, you don't need 1700V.
Edited by starcat
On 7/16/2021 at 7:46 PM, starcat said:
Stuffing some Carbon boards over here while waiting for parts...
Optimising the physical layout in the chassis.
I was wondering why is that 10M90S on the positive GRHV board mounted on that Aavid heatsink and not directly to the side heatsink as the others, any particular reason? It always gets in the way.
Edited by starcat
I think that 10M90S is for the bias voltage. I assume it doesn't get that hot, but don't know the actual reason for the on board heatsink instead of sinking it to the main heatsink/bracket. It does look like there is sufficient board real estate available to have done that instead.
EDIT: Kevin beat me to it while typing; go with his explanation.
Edited by Pars
4 minutes ago, kevin gilmore said:
that is the bias supply current source and is at at least 700v. best for highest isolation.
Thanks, Kevin! So, it should not be moved off that Avid heatsink?
I thought about mounting it downward facing and sticking it to the main amp's heatsink, same as the other sands (I would not be using brackets but mounting them directly on the heatsinks on the amp sides).
Edited by starcat
Another Carbon in the works, I received my panels and drilled heatsinks back today.
I haven’t put it together yet... I sure hope everything fits.
Adobe Illustrator preliminary file:
891829371_ScreenShot2021-08-13at3_38_18pm.thumb.png.c0097a3af4eb456934238187e60f0c8a.png
Edited by johnwmclean
More progress, it’s been a while since I tested one of these, I used Soren’s adjustment method for the CCS which worked well, dialled in for 19mA
Finally done!
This is a 400V, 19mA version, using the ground plane amp board, Sumr transformer and Goldpoint V47 attenuator. I bought the heatsinks from China and had all the drilling and panels done at Front Panel Express. I pulled out the Canon 5D from the cupboard for some tasty shots.
3 hours ago, johnwmclean said:
Finally done!
I was lucky enough to grab your old Carbon 😊
I could see subtle changes from your old Carbon - volume pot, one output instead of two, ventilation holes at the back, directional changes to the XLR input/outputs am sure it would be sounding A M A Z I N G 👍
kgsshv-carbon.1878979
Nicely done!
What brand of attenuator did you get? Balanced quads are quite expensive
On 8/22/2021 at 2:17 AM, johnwmclean said:
Finally done!
this would look great next to my kerry t2! lol, what are the outside measurements, this build looks tight!
It really isn’t patch on Kerrys magnificent builds, he’s on a whole other level.
  • 4 weeks later...
Hello all!
After succesfull build GG moved to Carbon (board version 0.6). Soldered all components. Tested Right channel - all good.
But with Left chanel some problem: with [balance] test all ok, [Current Adjust] seems also good. But problem with [offset]. It has voltage 405V (with +P left channel, same as -P). When trimmed [offset] it has diviasion +-10V. But it is not enougth for set 0V. All resistors with their nominals, seems no short circute, LEDs glows.
Where could be problem?
Edited by bbest
Left chanel say hello to grave: half sands went to trash 😅 . Now looking for DN2540N5-G and C2M1000170D, but they are out of stock. Could someone suggest by which analogs it could be replaced?
