Massdrop Cavalli Tube Hybrid
1 hour ago, dsavitsk said:
Sometimes flipping toroids will reduce stray fields.
That could certainly be true, but I think that's giving way too much credit to the builder.
  • Replies 61
  • Views 34.1k
  • Been doing some testing using the Audio-GD as the dac... I've tripped the protection circuit on the CarbonX and the CTH just died when plugging in headphones.  Returns for Massdrop will be
  • kevin gilmore
    kevin gilmore
    8significant areas on both units have circuit board heatsink area. Still you could easily attach real heatsinks to those areas and put more holes in the case to let the heat out. And then bias up the
  • kevin gilmore
    kevin gilmore
    Even with the grossly inflated prices cavalli eventually went under due to too many hands in the cookie jar and shit quality requiring a lot of repairs, especially the liquid carbon. when there w
On ‎2018‎年‎3‎月‎11‎日 at 2:26 AM, spritzer said:
What's up with those V-caps?  The circuit is fully DC coupled so special insanity?  I do like the cloned chassis though...
As it turns out I have my fans as well...
https://item.taobao.com/item.htm?spm=2013.1.20141002.7.7fbc42fdH73z3A&scm=1007.10009.70205.100200300000001&id=543961961161&pvid=4b6da6a3-603d-4eba-962f-6f36272bacf7
https://item.taobao.com/item.htm?spm=2013.1.20141002.5.7fbc42fdH73z3A&scm=1007.10009.70205.100200300000001&id=563080882986&pvid=4b6da6a3-603d-4eba-962f-6f36272bacf7
Even fake circuit boards as I never released the mini boards.   Those are completely wrong but since when has that stopped anybody...
Like many tricks in HiFi area,people are willing to believe expensive caps、wires、fuse、rhodium-plated sockets etc. can make sound euphonious,some
companies are to modify their crap stuff with high-priced materials and price the product at the much higher level to make people to think they are sound better.
"tone tuning",this is the word that I hear those people say most.
I often hear they say :  bhse is tuned for 007 not for 009 ,carbon has too much bass ,gg and megatron are tuned for listening vocals,kgss is more "analytical" than musical...
I've built bh/carbon/gg/mega,to me,they're all great amps in the same class.
“Voiced” is the other term I see used for I assume the same thing. As in “voiced to produce the designer’s signature sound” or some such inane bullshit. If this is a tube amp with coupling caps (and between stages), etc. then there are things you can or could do. A direct coupled SS amp, not so much.
I believe this is absolutely possible, through varying distortion harmonic levels. I think for example, dominant third-order harmonics, could be a “voicing” of sorts.
2nd harmonic and 3rd harmonic vs frequency is what influences sound signature the most.
bipolar vs mosfet outputs makes the most difference.
there is no cavalli house sound. This amp is bipolar outputs, the LCX is mosfet.
Wow, taobao is a dangerous place if they use other builder pictures for advertisement on building KG T2.  Who knows what they build it out to be....I hope it won’t bring KG T2 any negatives, or somebody need to pull some strings
It only works on one phase.....?
Yes, you're right, and an oversimplification on my part.
I doubt people will base a proper product with the China fake counterpart. From Taobao especially.
Though I do have a friend who keeps buying Aliexpress opamps and raving how good they sound compared to the stock opamp in his class D amp. Only time I go to Taobao is for their chassis, can easily cost less than half or a third of eBay prices.
8 hours ago, justin said:
I'm curious what happens if you order the Singlepower
Somebody in China tries to make a clone and fails... :lol:
There's one thing i can't understand is that according to massdrop measurement, this amp has really low THD+N : only 0.0025% https://www.head-fi.org/threads/massdrop-x-alex-cavalli-tube-hybrid-amp-cth-dropping-monday.857673/. If it's a simple tube gain stage coupled to solid state buffer like the original  CTH no way it could have such low THD. Even the schiit Vali2 with global feedback has higher distortion than the Massdrop CTH.
That is the usual Cavalli BS.  No way that the distortion+N is that low.  I could test it but I kinda broke the tube when inserting it into the amp.  :ph34r:  I did order some new ones...
the thd+N is .0075%, and although it does not specify, its likely at 1khz.
look at the schematic posted above.  about 15db of feedback around the grid of the tube. Lowering the input impedance to bipolar levels or lower and kind of negating any possible use of an input tube. Also the plate current source.
spice indicates a second harmonic distortion of -74db at 1khz (.02%) and a 3rd harmonic distortion of -109db (.0003%) at 1khz
however at 10khz the second harmonic is -60db (.1%) and the third harmonic is -96db (.002%)
you can work out the summation on your own.
plus of course the messed up soundstage due to the inverse phase. Something the plankton experts seem to ignore.
In reality, with an old school analog thd meter, the numbers are going to be much much higher.
and of course this is all measured with a 300 ohm resistor. Use a real load especially low impedance, and the numbers go way up.
so spice indicate at least 0.02% thd at 300ohm, real world measurement must be worse, can't understand their spec 0.0014% at 50ohm but at the same time i dont' believe some big company like cavalli do some marketing shit like that.
Mikhail did the originals....  and failed....:lol:
It's called Audiophoolery........:P
23 hours ago, Thai Tao said:
... i dont' believe some big company like cavalli do some marketing shit like that.
Sorry, but Cavilli wasn't some big company, it was basically one guy, Alex Cavilli, and it's no longer in business.
when there was only one standard for measuring distortion it was easy. Now that there are a number of adc based distortion devices each with different firmware and software, and digital filters you can generate impossibly low distortion numbers that are meaningless.
jude might want to look at how measurements were done many moons ago and emulate that. Far more useful information.
i think a reasonable number on sales exceed 8M$ over the 8 year life of cavalli. Lots of people are going to take a bath, just like singlepower
million per year, it's a lot of money for a small business... :blink::blink::blink:
Disastrous management :wacko:
Not once you deduct the cost of running a company, building product, and paying taxes. With 8M gross revenue, it probably lost money — must have, or it would likely have stayed in business.
