Kerry Design mini GRHV\GRLV and JoaMat mini T2 Group Buy
Table updated.
Blank in the GRHVxxx-bare column indicates that the participant has not responded on this thread to indicate the preference for bare or partially-assembled boards and is deemed to opt for partially-assembled board by default as previously communicated.
Edited by mwl168
  • Replies 421
  • Views 121k
  • Just got a few boards in.  From left to right... GRHV78xxx, GRHV79xxx and to the right is a new experimental digital alternator.  It’s stackable for balanced
  • Look what I just found at my door step...
  • Here's some pics of the power supply inside a Canon build...
I'd like to add to what I'm getting.  I'd like 1 set of partially-assembled and 1set of bare boards.
So:
2x GRHVxxx partially-assembled
2x GRHVxxx bare
2x GRLV79xx
2x GRLV78xx
2x Main Board
2x miniT2
Thanks!
56 minutes ago, mwl168 said:
The GRLV boards can work as direct plugin for the 78xx/79xx parts.
Thanks!
Could you please revise my quantity to:
6x mini-T2
1x mainboard
2x GRHV (bare boards)
1x GRLV78xx (bare board)
1x GRLV79xx (bare board)
could i be added to this group buy for
2x mini-T2
1x mainboard
1x GRLV79xx (bare board)1x PSU main board
best regards
Edited by harmony
politely asking
I'll opt for partially assembled boards, thanks.
Can I add four more bare GRHV boards, two more GRLV 78xx, two more GRLV 79xx, and two more main boards?
Thank You
I would like partially assembled boards as well please.  Thank you very much for doing this.
i go for partial assembled boards, thanks for your work 🙂
Edited by rumina
Hi Purk:
I don't believe you had joined the GB earlier. Can you specify which and how many boards each you want?
Table updated.
Edited by mwl168
@mwl168,
Please update my request:
4x GRHVxxx partially-assembled
2x GRLV79xx
2x GRLV78xx
2x Main Board
1x miniT2 (pair-right&left)
Cheers,
Bob
@mwl168
I will go with bare PCBs.
Is there a BOM posted for these boards anywhere?  I looked through the thread but didn't see one.  Apologies if I overlooked it.
Thank you for all the time and effort you have put in getting this GB organized.
Table updated!
BOM for boards will be posted soon in the first post of this thread.
partially assembled
Sent from my Pixel 2 XL using Tapatalk
Edited by nopants
Table updated.
It's time to wrap up this GB. Please post your decision for partially-assembled/bare GRHVxxx boards and updates to the PCB quantities by end of Sunday, March 22. I will then get quotes from the fab house and start collecting payments so we can place the order to have the boards made. Again, I would assume you opt for assembled GRHVxxx boards for those that do not respond.
For those GB participants that are new to Headcase (less than 10 posts) and have not responded since last Tuesday, March 10, please post your response here so we know you are till participating.
Edited by mwl168
I would like to revise my position as follows :
2 main boards
2 LV78 and 2 LV79
2 HV partially asembled
2 bare HV
Thanks!
I'd like to upgrade my quantities if possible:
2x preassembled GRHV's
2x bare GRHV's
2x GRLV78xx
2x GRLV79xx
2x T2 PSU board
2x T2 board
(Didn't realize the prices would be so good)
We don't need GRHV's for the T2 mainboard right?
Edited by nopants
2 GRHVxxx boards are needed for the PSU. GRHVxxx are not needed for the mini T2 boards.
Please add 2 GRHVxxx bare boards to my order, in addition to the 2 assembled boards already there.
Thanks
Randy
posted BOMs in the first post of this thread.
The BOM for GRHVxxx and PSU MAIN boards should be up to date. Need to check the GRLV boards BOM.
