March 11, 20206 yr Author Table updated. Blank in the GRHVxxx-bare column indicates that the participant has not responded on this thread to indicate the preference for bare or partially-assembled boards and is deemed to opt for partially-assembled board by default as previously communicated. Edited March 11, 20206 yr by mwl168
March 11, 20206 yr I'd like to add to what I'm getting. I'd like 1 set of partially-assembled and 1set of bare boards. So: 2x GRHVxxx partially-assembled 2x GRHVxxx bare 2x GRLV79xx 2x GRLV78xx 2x Main Board 2x miniT2 Thanks!
March 11, 20206 yr 56 minutes ago, mwl168 said: The GRLV boards can work as direct plugin for the 78xx/79xx parts. Thanks! Could you please revise my quantity to: 6x mini-T2 1x mainboard 2x GRHV (bare boards) 1x GRLV78xx (bare board) 1x GRLV79xx (bare board)
March 11, 20206 yr could i be added to this group buy for 2x mini-T2 1x mainboard 2x GRHV (bare boards) 1x GRLV78xx (bare board) 1x GRLV79xx (bare board)1x PSU main board best regards Edited March 11, 20206 yr by harmony politely asking
March 12, 20206 yr Can I add four more bare GRHV boards, two more GRLV 78xx, two more GRLV 79xx, and two more main boards? Thank You
March 12, 20206 yr I would like partially assembled boards as well please. Thank you very much for doing this.
March 12, 20206 yr i go for partial assembled boards, thanks for your work 🙂 Edited March 12, 20206 yr by rumina
March 12, 20206 yr Author 11 hours ago, purk said: I would like partially assembled boards as well please. Thank you very much for doing this. Hi Purk: I don't believe you had joined the GB earlier. Can you specify which and how many boards each you want? Table updated. Edited March 12, 20206 yr by mwl168
March 12, 20206 yr @mwl168, Please update my request: 4x GRHVxxx partially-assembled 2x GRLV79xx 2x GRLV78xx 2x Main Board 1x miniT2 (pair-right&left) Cheers, Bob
March 13, 20206 yr @mwl168 I will go with bare PCBs. Is there a BOM posted for these boards anywhere? I looked through the thread but didn't see one. Apologies if I overlooked it. Thank you for all the time and effort you have put in getting this GB organized.
March 13, 20206 yr Author Table updated! BOM for boards will be posted soon in the first post of this thread.
March 13, 20206 yr Hi, please add to my outstanding list: 2x GRLV78 2x GRLV79 thanks for all the work!
March 16, 20206 yr partially assembled Sent from my Pixel 2 XL using Tapatalk Edited March 16, 20206 yr by nopants
March 16, 20206 yr Author Table updated. It's time to wrap up this GB. Please post your decision for partially-assembled/bare GRHVxxx boards and updates to the PCB quantities by end of Sunday, March 22. I will then get quotes from the fab house and start collecting payments so we can place the order to have the boards made. Again, I would assume you opt for assembled GRHVxxx boards for those that do not respond. For those GB participants that are new to Headcase (less than 10 posts) and have not responded since last Tuesday, March 10, please post your response here so we know you are till participating. Edited March 16, 20206 yr by mwl168
March 16, 20206 yr I would like to revise my position as follows : 2 main boards 2 LV78 and 2 LV79 2 HV partially asembled 2 bare HV Thanks!
March 16, 20206 yr I'd like to upgrade my quantities if possible: 2x preassembled GRHV's 2x bare GRHV's 2x GRLV78xx 2x GRLV79xx 2x T2 PSU board 2x T2 board (Didn't realize the prices would be so good) We don't need GRHV's for the T2 mainboard right? Edited March 16, 20206 yr by nopants
March 16, 20206 yr Author 19 minutes ago, nopants said: We don't need GRHV's for the T2 mainboard right? 2 GRHVxxx boards are needed for the PSU. GRHVxxx are not needed for the mini T2 boards.
March 16, 20206 yr Please add 2 GRHVxxx bare boards to my order, in addition to the 2 assembled boards already there. Thanks Randy
March 16, 20206 yr Author posted BOMs in the first post of this thread. The BOM for GRHVxxx and PSU MAIN boards should be up to date. Need to check the GRLV boards BOM.
