Speaker Porn
  • Replies 2.4k
  • Views 718.9k
  • Craig Sawyers
    Craig Sawyers
    Ah - the good old battleship grey Cambridge Audio livery. It was panned by the reviewers, as were the buttons on the CD player (they described them as reminiscent of poking dead flesh). Very unfair, b
  • R5s arrived:
  • I dunno, can i post this here? The leather was just an idea - making some matching wood pulls would be cool - maybe when things die down at M&O of course my speaker cables are too short
Um, wondering if those pics (as origional and fun as they are) might be better served in a DIY section of the forum; this thread seems more for the lusty and sexy make-you-want-at-any-cost variety of speakers.
This is not to write that it's like someone stepping into a gorgeous naked woman picture gallery and uploading a picture of a hairy man butt sporting a gerber jar; well, sort of I guess
Hey Pedalhead! Welcome to Head-Case. Awesome sounding always counts.
Yeah, I do feel rather like the ugly bloke who just stepped into the Claudia Schiffer thread. Gods/mods, feel free to eject my hairy arse-speakers into the DIY forum if necessary, no hard feelings :asshat:
edit - although...there is a bloke with antlers attached to his headphones up there
Me thinks you will like it here and do well . . . but you will now have to find and post pictures of Claudia's crossovers.
Oh, and the antler man pic? Submitted by some sort of post-bot (aka attorney) that occasionally gets through the site's filters.
Ah well, the barn's been there for 200 years & the subs have been there through a year of heavy use, I'll take my chances ;). Having said that, I'm kinda tempted to move my bikes...
Hypothetically speaking, since I'm not giving advice in any official capacity you'd want to make sure of at least two things:
1. That you have not used nails in tension. Nails in tension will creep over time and back their way out of most holes.
2. That whatever screws that you have used are rated for tension loads. Lots of people like to inappropriately use drywall screws for everything and they have little to no tension value.
Basically I'd hate to see a creation like that fail, I'm a fan of function over form so I like them a lot. And what concerns me is that your floor probably moves a bit when you walk on it and that'll be what eventually causes a problem at the attachment points.
Going back to the prosaic and unlikely-to-cause-squishage end of the speaker spectrum...
I really like the look of these as desktop or HT speakers. They're small(ish), slick (to me) and spec'ed to play down to 45Hz with some boundary reinforcement. The Gallo speakers I've heard in the past have also sounded superb -- the cylindrical diaphragm tweeter is a real treat. Al used to own some Reference 3.1s, I think, and will probably back me up on that. Nice little integrated desktop stand, too, it looks like.
I'm probably getting a pair of Stradas for a 2.1 system, which will eventually expand to a 4.1 system. It's basically a Reference 3.1 less the bottom-most driver (wasn't sure whether to call it a woofer or a subwoofer, but...you know what I mean).
In this case, I think it's basically a Ref 3.5 minus etc. -- although those aren't out yet. They've made some changes to the tweeter, added outrigger stands and doubled the price of the floorstanders. :(
Cheers, I've sent you a PM to bore you with the details. Don't want to derail this mighty fine pr0n thread any more than I already have :) .
Can't remember if I've seen these here but VIVID Audio's GIYA speakers designed by the guy who designed the B&W Nautilius Speaker
Mmmm! DairyQueen anyone?
Looks like an old Akai drum machine in the middle picture. I'm going to guess that's Pharrel's rumpus room.
I think what you are seeing is the keyboard part of a Phillips LHH-2000 CD player. Incredibly rare machine
http://www.marantzphilips.nl/index.asp?strPage=Info&strBrand=Philips&strType=lhh2000
Did anything ever come of those ribbon-based headphones?
I'm guessing he backburnered them until (a) he could figure out the magnetic-waves-drives-wearer-crazy problem (or a.5 find out a way to drive them crazy in a way that spends more money on ribbon speakers); and (B) concentrating on the speaker thing.
He's probably mulling over the first problem in the back of his mind, but not devoting any intentional clock cycles to it.
Is there an equivalent to the Faraday cage, except for magnetic waves?
I was also considering suggesting to him to try it on a significantly smaller scale, to reduce the problem by sheer scaling down of the cause of the magnetic waves -- say, IEM's, but where the ribbons themselves don't go into the ear. (But you don't want to make them too far from the opening, as I'm sure that will cause its own share of problems, acoustically.)
Sanity check?
Magico Ultimate II
Height - 90", Depth - 60", Width - 48"-18". Four compression drivers and a powered subwoofer. The baffle is milled from a 4" thick slab of solid aluminum. 22Hz-30KHz.
"Weight -- 800 lbs (363 kg)" :D
LOL - I suspect that what you are looking at is the DAC portion of the Phillips LHH-2000. BIG dollar machine even now.
Those look like big Pass X250s driving those magicos. Since the sub is powered, that man is using oodles of Pass watts to drive a series of compression horns that are probably 90+ dB efficient, even with the crossover.
It is, in effect, like strapping a rocket on a jet. Awesome.
Could be a Pass X1000's since they all look the same...
Of course. One would hate to miss out on those stunning 120 dB peaks...:o
It still probably sounds hella good since they are class A to something like 60 watts? Give me that over a tube amp.
Oh and Pacific Microsonics digital in that picture... ftw ^-^
Even the smallest Pass X-series is at least 15 watts of class A, and I doubt you'd push more than 15 watts through that rig at any given point, so I am wholly in agreement with you.
Also, missed the digital. This guy knows what's up.
