Which Cooking Are You?
Also, I made the mistake of touching my nose after handling the chile peppers. OUCH. FUCK ME, REALLY. OUCH.
i see the folks on food network wearing gloves and sometime even masks when handling hot peppers.
hope the effects are wearing off by now...
  • Replies 3.2k
  • Views 676.5k
Next time try rubbing yogurt on the burn sometimes that helps.
1.6" thick filet mignon, so if my math is right, it should be done in about 1.5 hours (been cooking for a bit already).
That is because that picture is only about 25 minutes into the cook cycle, Gene. The steak is still raw at that point; I was measuring the temperature of the water surrounding it. About 10 minutes to go, should get the cast iron heating.
Edited by cetoole
Cooked it for an hour at ~130 degrees. Then seared it for ~1 minute per side on cast iron that was smoking so much more smoke detector went off.
Your heat gun has a 130 degree setting? Does your arm get tired holding the heat gun for an hour and a half?
Lots of practice....
No, he puts it in a 'helping hand' type thingy.
Oh, this one
Or was it the other (Hizamakura) pillow?
Looks like a nice recipe site the one with your mac and cheese recipe, I just bookmarked it. And the bread looks yummy!
Edited by GPH
I'm sure that bread is awesome, but I think it would be epic if you put an eyeball in that sphincter because it would look like a cyclops monkey!
heh, but then i'd have to get a pot dirty boiling the egg!
You're not doing it right if the pot gets dirty. ;)
heh. well, i have a secret for hard boiled eggs: crack the shells slightly a couple minutes before you take them out. it makes removing the shells really easy, but it means you get some egg protein in the water, which dirties the pot. i definitely recommend it, though. the shells come right off. it's even better than using old eggs.
We will try that. Debbie says Thank You!!
I just boil them and them stick them in a bowl of freezing water right out of the pot.
