Which Cooking Are You?
  • Replies 3.2k
  • Views 656.1k
Not cooking right now, but there were a lot of good tips in here:
I'm curious if you all agree with the advice to take the oil well past it's smoke point -- that's not at all what I did.  I also probably left too much oil on, as per the video.
Ham, crumbs, chutney + Pinot Grigio
Edited by Mario_Fpolis
On ‎10‎/‎30‎/‎2016 at 11:39 PM, EdipisReks1 said:
Haven't watched the video. When doing high temp searing, a lot of smoke will be produced.
I picked up a two carbon steel pans to try out.  The first time I used them, I forgot that smoke can be an issue with high heat and before I knew it the kitchen was full of smoke. Now, I make sure the hood fan is on.  So far, I love cooking with them but it can be challenge to keep Gail from taking a sponge and soap to them.
11 hours ago, tyrion said:
I'm seasoning as I use them.  I clean with paper towel, no soap or water and coat with oil while stored.  I prefer the pans to my grill for most items I would grill, like steak, pork chops, etc.
Watch the video, she espouses a convincing argument for seasoning the entire pan, not just the cooking area.  I'd be curious if anyone else would be convinced.  I'm also curious if it's a bad idea to coat the pan with oil -- which is flammable, neh? -- on the flame side at all, since she never addresses the issue.
The whole interior surface of the pan should be seasoned prior to use, in my opinion. A little oil on the bottom isn't going to hurt, but don't season the bottom.
A little soap and a soft sponge isn't going to hurt the seasoning, btw, Mike.
Edited by EdipisReks1
I seasoned the bottom of my carbon steel pan, and now it slides around on the stove once it gets hot. I should probably strip and re-season it.
So you found a pan with the same traits as you... live with it. Heck, enjoy it even.
I will occasionally use a sponge on my pan but mostly just clean it with some paper towels and if needed, leave a coating of all, similar to my kitchen knives.  With the knives, mostly just run under faucet, driy with towel and put up on the magnet.  From time to time, I will put some oil on the blades.
My carbon steel wok. Can't even remember how I seasoned it originally - it was ten or even fifteen years back. I just rinse with a sponge, dry and wipe over with some oil.
Edited by Craig Sawyers
On 05/11/2016 at 0:22 AM, Dusty Chalk said:
You say, "a little cunty"...I say, "this is news?".
Someone change my personalized subtitle to "a little cunty", I can't figure it out.
That said, still want.
I like this variation. (Not in reference to you Dusty. Just in general.)
Allison and I will be hosting Thanksgiving for the first time and so we're doing a Turkey trial run. It's resting so not sure how it tastes yet but the damn bird looks good to me
