The Multi Amp aka Dynalo Mk2
Looks great! How much was it grand total?
  • Replies 1.6k
  • Views 518.6k
  • johnwmclean
    johnwmclean
Beautiful! Now...get yourself a dynamic can and let us know how it sounds :)
^ I acquired a pair of Ether Flows.
Hey who's counting? This is Head Case dammit.
 ... around $320US plus shipping.
ouch, maybe time to revive the group buy thing again
at 75 pieces it goes down 30%
I'll take some time this week to see if I can get a proper dollar amount
Finished assembling this,pretty comfy color :)
Edited by ang728
How would you describe the sound? Top and bottom units are identical except for the orientation of the power inlet?
That looks fabulous - and I love the color! :wub:
How did you get that finish, because the cases look like the eBay-ones that are normally silver?
//UFN
Those were a GB ang728 and I ran locally. It was supposed to be silver, or grey, or gun metal - at least in our imagination. We ordered something like that. When the factory gave us some pictures of those...Say 30 of those. It's simply too late.:P It was done by accident and I assume it's impossible to reproduce again. I believe something was wrong in that anodizing sink. Who knows. I love them a lot.:D Because of the color, the power indicator is also green.
Yes,both amps are the same except the orientation of the power inlet
Heh, OK - as accidents go I think it's a happy one :D
//UFN
Yes, very nice work, and love the color! Are those based on Kerry's mini board?
it fits with full-size one not Kerry's mini board :)
1 hour ago, HemiSam said:
Any internal shots?
HS
Still crappy wiring jobs
You seem to have a very fruitful collaboration, ang728 and jeohpj. Congratulation to really nice amplifiers.
Hey guys! What's the currently approved best solution to cool mini Dynalo transistors? @johnwmclean , did you have much luck with thermal tape?
Options are limited;
1) Use a permanent epoxy/glue and risk not being able to access parts again.
2) Use non permanent tape/glue and risk the heatsink becoming loose and shorting something.
3) Let em run hot.
I’ve adopted option 3, have measured ~74°C, with an ambient of 24°C after an hour fully cased. Not ideal, but not catastrophic and well within running spec.
Thanks for the info! I have considered glueing small carpentry nails to each of the transistors. Epoxy or super glue might hold them well enough.
