2018 PCB Group Buy with TKD pots
  • Replies 347
  • Views 99k
  • Everyone is sorted...  Geez that was a ton of boards.  I'll head to the store tomorrow for envelopes after I sort those who didn't order a TKD pot.
  • I opened the boxes today. I’ll take some shots tomorrow since today’s my birthday Sent from my iPhone using Tapatalk
  • Packaging the THAT340 boards today since I had some time.  There's extra in case anyone wants extra sets
Hello,
Please add me for a set of Dynalo Mini with TKd pot and PSU boards.  I appreciate.
^ Link in the 1st post to place your order...
agree, yes,  four sets  power supplies,  many projects to  be completed.
I changed the quantity to 2 sets
Edited by samsie
I double check my stock and realised that I have three sets at home already
Yes indeed. :) I have a few things in the work that these 4 will be for.
Would anyone be interested in getting Grounded Grid or KGBH boards? I can provide gerbers. I'd like to get one or the other (or both) but if no one else is interested I'm not gonna rock the boat etc.
I can add them to the sheet.  Are parts easy to be found for the KGBH?  I always wanted to build that
Not the original one at least (2SA1968s for starters). I did see a thread for a BJT build of this, but didn't go thru it. One of the stat guys can advise you much better than I can though...
There is a new version KGBH that uses current parts. I ran a GB on it last year. In addition to replacing the 2SA1968 as the CCS parts as Pars pointed out, this version also replaces the 2SK216/2SJ79 JFET with current production BJT parts.
I would be in for another set of these boards.  The BH-BJT has become my favorite amp these days.  Just love it.  I would like to have another set of boards in case my son or brother decide they cannot live without one. Here are the gerbers. kgbhver6sbipolar.zip
Edited by Blueman2
20 hours ago, gepardcv said:
I'd be in for a GG set.
Awesome. I can upload the gerbers tonight when I get home if we want to add this to the sheet?
17 hours ago, Blueman2 said:
I would be in for another set of these boards.  The BH-BJT has become my favorite amp these days.  Just love it.  I would like to have another set of boards in case my son or brother decide they cannot live without one.  I will add the BH-BJT to the sheet.  Here are the gerbers.   Not sure what the dht version is vs other.
kgbhver6sbipolardht.zip
Not 100% sure of the differences either. Does anyone know? Quick glance shows multiple heater connections
Also curious if GRHV is the best PSU to use for this or if there is a different BH PSU that should be used? Gonna do some reading on the threads here tonight to try and find out.
I think these are the latest gg Gerbers.  I will add to the spreadsheet.  Since tubed, I will spec 2mm board thickness.
gg.zip
Yes, these work well with the BH.  Good clean power with the ability to add timer function for the HV section.  This allows the tubes to warm up for about a minute before the HV kicks in.  The only real question is whether to use the on board Low Voltage which the GRHV provides, or whether you want to go with separate GRLV board(s).  I used the GRHV on board LV supply and it works fine on my BH-BJT.
Edited by Blueman2
45 minutes ago, kevin gilmore said:
don't build the DHT one unless you plan on spending piles of cash on tubes
Ah!!!  Direct heated triodes!  That is what dht meant.  Thanks for the clarification.  Removed the DHT files and left only the regular one.
what were the tubes for that one?
Some model of Emission Labs maybe?
seeing only a few people have signed up for Carbon boards.
I have some version 6g from PCBNet 2mm/3oz, that I don't mind departing from (16.75USD/ea). If interested shoot me a PM.
EML 20B V4. Only $500 each.
Good lord that’s enough to build another amp
That’s a good deal... make sure to remove the carbon from your name in the sheet
But they come in a gift box!!
Cheaper than WE300B reissued ! :rolleyes:
JAC Music got  a pair for ~500usd, still pretty steep for a set of four.
Would the GRHV be appropriate for a 12ax7 + 6V6 play thingy or is it overkill or the wrong purpose altogether?
I am playing around with some tube preamps but in a low voltage scenario at the moment since I don't have a high voltage power source currently.
Edited by masamoto
Hi,
Is the tube bal/unbal with power supply one stereo set? (I still want the reserved SS ones too)
Steef
Hi,
Steef
I’ve got your SS set put aside. I have to look at the Gerbers tonight to see if it’s one board per channel for the tube
