JH Audio stuffs
  • Replies 4k
  • Views 936.3k
  • So a while back I washed my jh13's and one earpiece had a hole so the drivers got wet. Decided I had enough, put them in a draw and forgot about them. A week or so ago, I decided to see if they could
  • I may be going on a limb here but I am guessing you prefer your 780p monitor over your friend's 4K Samsung. My brother in law had the same preference when he told his wife on their twenty second
  • Leonardo Drummond
    Leonardo Drummond
    It's here!
Won't have time to pick them up as I am trying to figure out how to get far enough south that I can fly out tomorrow to Miami. I am thinking tomorrow will be Planes, Trains and Automobiles for me.
Mine just came in. Any tricks on comfortably inserting and removing them? Kind of hurts pulling them out. I think the left one might be a bit too big/tight to begin with.
You read the manual, right? Insert using a slow twist , starting 90 degrees from their final orientation. Reverse the process for removal.
Having said that, My right one is much easier to deal with than the left, which was exactly the case with the impressions ( the left one didn't seem to want to come out at first).
Gets easier with practice, but take it gently at first.
"Popping" them out a touch to break the seal seems to make removal easier, try tugging on your outer ear lobe a bit to see if that helps with the process.
Yet again, welcome to the team. :)
w00t! to Dan on ordering and Naaman on receiving! Damn, that sucks Jeff. Travel drama without the JH13s will be much more painful than if you had them. Sorry.
Naaman, don't screw around. If they feel like they don't fit, then they probably don't. Wear them for a while, check out an ear diagram online, identify the problem area and send 'em back. Not worth it to live with less than perfect fit.
Just tried the TWag balanced cable on the JH13 using my new luvdunhill JFET-tastic amp. Sweet combination. Much goodness may come of this setup. O0
I'm interested to hear how the 13's are with the jfet-tastic amp (lol, nice). Keep us posted on the much goodness ;D
Great news Al! That amp designer is a bit eccentric, but brilliant none the less. :D
Fet-tastic is a great name for that amp.
Since I bought my first JH13s before they became FOTY and this thread had started I never got to show off my new ones. So JH13s Part Two will get the honor.
All I need is a little Pico Slim to attach to the back of the Nano and I will be set.
Yeah, I really like the color and the fit is the best of all my customs. I just wish the fancy case that I used to hear about them coming with was available. My previous case was better than the little clear Pelican knock-off I got this time.
Red looks great! It might be a stupid question, but does it sound the same as your former pair?
In my case the definitely sound better as I had fit issues with my first ones that I never got taken care of. These have a very nice seal and are sounding quite good, even without 1,200 hours of burn in.
