Another One Bites The Dust: SDS-DOA
Ironbut has a reel-to-reel source.
-> I hate him.
Ironbut fixes Single Power amps.
-> I love him.
  • Replies 264
  • Views 49.2k
-> I love him.
-> I really love him.
Fixed! :D
latest singlepower clusterfuck here
Supra Schematic? - Head-Fi: Covering Headphones, Earphones and Portable Audio
and a smoked singlepower supra extreme slam se with pictures soon.
If the person that is going to fix this is as good as i hope they will be, then
maybe we can find a way to get him to drive over to mikhail's with a truck
and pick up all the dead stuff and then charge people to fix it. He is only
75 miles away or so...
Ironbut really did it! I finally have proper tubes in all locations and he really fixed the damn thing! I tried with some crap tubes because that was all I had in SF and they sucked and there were problems with the sound and drop outs etc. as I mentioned above. I then borrowed a couple mismatched 6sn7s from blessingx and it was better but Ric said one was suspect and he was right. Today I went to Mayberry to get my tubes and I put in all good tubes and the beast is back!
It sounds great without any problems, distortion or anything else to get in the way of the sound. I am so relieved and psyched to have this resolved. No more meets for this frail flower and if anything further goes wrong then the KG design is going into play.
Thanks again to all who helped but special props go out to the miracle worker in iron. :)
Cool! If you're looking down the road to just try the KG supply for the heck of it, I'd love to have a go at it for you. I have a few ideas of my own but they are in early gestation stages... and involves, among other tubes, a 12AX7 in the PSU for an error amplifier, which could be sorta weird for people... but, maybe I could just barely gain the KG seal of approval :)
Just for the heck of it, I'd like to know the output voltages and currents though, if anyone happens to have a rough idea.
I don't have a clue what you are talking about but that would be fun! We should talk when you are not traveling and maybe you could have it as a back-burner project I would fund. You get to experiment and I get to have an alternative flavor of amp and a backup. Win. Win.
Hope you are enjoying the road trip.
Glad to see everything is back up and running Voltron.
There's also CERTIFIED-Singlepower MPX3 SE EXTREME - Head-Fi: Covering Headphones, Earphones and Portable Audio for sale... what IS a mpx3 extreme? some sort of new clusterfuck hybrid? same with a supra extreme? :confused:
Hmmm, must be a Charlotte meet coming up.
Beat me to it. :P
:prettyprincess: Great news Al!
My personal amp is a ppx3 extreme.
Back then mikhail built about 50 mpx3's and ppx3's and was unable to sell them.
So he tore them apart and rebuilt them as extremes. Including the completely
underpowered transformer.
There are only 3 different chassis sizes, and 2 different circuits total.
Plus all the custom stupidity. (dynamic amps only)
My tube power supply design was such that it used existing tube socket
holes, and did not require any chassis work. I can certainly build all
tube power supplies that regulate to a fraction of a volt. Basically copies
of the old tektronix stuff. Requires very custom transformers with lots
of isolated taps. Would not fit in that box.
ah, clever. I was sorta wondering about that.
I had him rebuild my ppx3 into an extreme. Mine is the platinum version with the plitron transformer. Do you have any idea of what plitron Mikhail used and whether it is underpowered too?
You just think that it is a plitron transformer because you have been told it is.
Given the events of the recent couple of months, how do you really know unless
you pop the cover and look. plitron transformers, every one i have ever seen going
way back are all toroids and won't fit into the square box. So if you still have
the 4 inch x 4 inch square box there is no way a plitron toroid is going to fit in there.
If you have the round cover then there is a good chance you really have the
right transformer. Then there is the issue of what particular model number it is.
Here is a big hint. Nothing mikhail has ever done that i have seen so far has custom
transformers, everything is a stock model. His line that he had the transformers custom
made is pure bullshit.
If the transformer runs so hot that you can't touch it after it has been on for an hour,
it is likely that sooner or later the transformer will let go.
When that happens a custom transformer is about $107. But then it ends up looking
like mine does now instead of what it used to look like.
I've just looked thru all the plitron standard product and there is no
standard part that comes even close to the required power and voltage
requirements. So if it really is a plitron, it would have to be a custom
thing. Something like 120vac output at .5 amp, and 6.3vac at 10 amps.
Kevin,
Even the plitron model Extreme's still wouldn't support the big output tubes and required an external power supply for the 10A filament tubes. So I'd expect the Plitron to carry 120V/.5A and maybe a 6A filament winding. I still don't see anything that looks right in the Plitron listings...
After sweating out some odd distortion/static since late last night, I finally realized that an update to the Amarra software had somehow pegged the main output in the red. I thought I was going nuts, especially since mostly low-rez files showed the static and the Luxman made it much less noticeable or not noticeable on some tracks. Oddly enough, it just goes to show how resolving the SDS-XLR really is. :P
I doubt that. The short time I had it hooked up to my Audio Aero, it seemed very resolving.
