The Headcase Stax thread
I've got a little leech cable Birgir made me that will allow just that :D I just need to bring one of my SRD6's.
  • Replies 14.4k
  • Views 3.4m
  • bwck2000
    bwck2000
There's a McAlister EA-4 on head-fi that's in Australia and I'm a little tempted to grab it. How good/bad is it?
The big ES-1 is taking up all my time plus some PCB work on the side. Once the big ES-1 is up and running then I can start work on the mini and draw up the PCB. I'll probably draw up the Egmont as well since it is so simple with feedback and all. :)
Worse then bad...
McAlister used to be thought of as "worse than Singlepower". I'm not sure that's the case any longer.
Didn't that McAllister FS specify that it was the "only properly working McAllister amp"? That should be a red flag right there, if ever there was one.
Hi all,
Recently I acquired a replacement Stax cable.
Could anyone determine for which type(s) ear speaker it is intended?
(Just curious to know it....)
Some characteristics (see picture of the cable):
* the continuous and dotted lines are gold coloured
* the cable is matt black
* the length from the tip of the connector pins to the feedthrough at the speaker side is approx 2.39 m
* the overall width of the cable is 13 mm
* the connector is a 5-pin gold plated type
I might use it for a SRX-mkIII (or mkII with torn membranes I have to repair) after a planned conversion to a pro version.
Or even to improve my Jecklin Float. The capacity of the stock cable of a Float is so much higher than the Stax cable, causing an unacceptable and unnecessary high load to the amplifier. But than I have to get a high bias voltage to the Stax connector (1200 or 1500 V for the Floats, depending on which type it is). And I might forget to set it back to the 580V Stax voltage before I connect my dear Stax....
Not a good idea at all, when I think about it; I'll stick to the Hirschmann connector for the Float and find an other type of lower capacity cable for the Float without having to cut off a precious Stax connector ;D
Thanks!
It's a SR-Alpha Excellent Pro cable. The gold pins prove it is a PC-OCC cable and that is the Gamma/Alpha strain relief.
Thanks for your help Birgir !
(Is there anything at all that you do not know about Stax?)
Best wishes.
I've heard a good working McAlister, but I think it was an EA-6. And I doubt it's ever going for sale, because I have first dibs if it does.
EA-6 be ugly on the inside...
It works, it sounds great, and I have first dibs. I will not argue about its insides, because I've never seen them.
Don't you own a Singlepower amp? :P
Anyone know what design this amp is based on, just out of curiosity?
My my, look at those tool marks around the stax plugs. It's like a cave painting :)
I look at that picture and just feel the magic smoke aching to be free.
Quite a bit actually... :-[
There are a couple of possibilities, most of which are based on the earliest Stax amps such as the SRA-6S. It's such a rats nest that the pictures make it almost impossible to decipher. How about Al brings the amp to you next time you meet and you draw it up for us... no? ;D
Hi guys,
I just received my O2 headphones from Japan:D
My setup is SCD-CE595,SRM-717 (thanks veloaudio!),O2.
This is by far the most profound headphone experience that I have had to date.I'm listening to Scheherazad performed by the Chicago symphony and conducted by Reiner on SACD,this is my reference recording and I am hearing such fine detail that I've never heard before and everything sounds perfectly natural,I'm blown away.
Those Living Stereo SACDs are great.
This is my only one but I will make a point of seeking out others given how wonderful this sounds,any recommendations?
I just buy them all ;D
The audio quality is fantastic on all of them. But if you're seeking good performances my favorites are
Dvorak's New World Symphony.
Berlioz Symphony Fantastique
Tchaikovsky/Rachmaninoff piano concerto no 1 and 2 respectively
Strauss Scenes from Salome & Elektra
Strauss Also sprach Zarathustra
There are more, those are off the top of my head.
