Which Cooking Are You?
Yup all true and entirely understood before purchasing the temperature controller (I already owned the pot). That said, as of right now I am doing 2 steaks which fit easily and I used a thermometer to check the consistency and it seemed reasonably good (+/- 1 degrees) everywhere I looked. If I really like the outcome I will likely just invest in an Anova or similar rather than add a circulation pump.
It's an experiment and I am having fun with it.
  • Replies 3.2k
  • Views 667.5k
Well I can probably sell you a good temperature sensor cheap in a while if the results are as expected :)
A couple of tilapia filets in the water bath and Debbie made a red cabbage slaw with adobo and apple cider vinegar.
Think I am going to stick with the slow cooker and temperature controller for a few months and at least wait until there is some great deal on one of the real machines.
Searzall, torch and propane tank are here. As is a nice porterhouse which I typically shy away from since the cast iron pan was basically just boiling the meat (no good contact with the meat. Going to give it a try tonight.
Is there a reason not to stick a frozen steak in the water bath with the anova circulator? I get it tomorrow. Was wondering if thawing the meat was necessary or not.
Nevermind. I guess people do this all the time and just add an extra 30 minutes to cook time.
Edited by crappyjones123
Picked it up a short while ago. Initial thoughts....it's a lot bigger than I thought it would be. My pot is a lot smaller than I thought it was. It is plenty big for a couple of steaks and veggies. The sound it makes when turned on is the coolest. Too late to cook anything tonight but steaks for lunch tomorrow :)
Is that proscuitto hiding in there or did you go vegan on us?
Chicken Tandoori with curry winter squash. Wow, this plate disappeared fast.
I would do 72 hours at 212, for optimum bettering.  Don't use a vacuum bag, just dump it straight in.
... Then a final smoke on the grill?
