Which Cooking Are You?
Yup all true and entirely understood before purchasing the temperature controller (I already owned the pot). That said, as of right now I am doing 2 steaks which fit easily and I used a thermometer to check the consistency and it seemed reasonably good (+/- 1 degrees) everywhere I looked. If I really like the outcome I will likely just invest in an Anova or similar rather than add a circulation pump.
It's an experiment and I am having fun with it.
  • Replies 3.2k
  • Views 618.2k
Well I can probably sell you a good temperature sensor cheap in a while if the results are as expected :)
A couple of tilapia filets in the water bath and Debbie made a red cabbage slaw with adobo and apple cider vinegar.
Sous vide filet and chili-lime salad. Sous vide steak is insanely good.
Think I am going to stick with the slow cooker and temperature controller for a few months and at least wait until there is some great deal on one of the real machines.
Smashed taters go with everything!
Searzall, torch and propane tank are here. As is a nice porterhouse which I typically shy away from since the cast iron pan was basically just boiling the meat (no good contact with the meat. Going to give it a try tonight.
Earlier today I followed Jacob's advice of a longer stew time with more liquid and lower temperature, and the stew beef came out much more tender.  I had also left it in a bath with more orange juice than previously.
Is there a reason not to stick a frozen steak in the water bath with the anova circulator? I get it tomorrow. Was wondering if thawing the meat was necessary or not.
Nevermind. I guess people do this all the time and just add an extra 30 minutes to cook time.
Edited by crappyjones123
Picked it up a short while ago. Initial thoughts....it's a lot bigger than I thought it would be. My pot is a lot smaller than I thought it was. It is plenty big for a couple of steaks and veggies. The sound it makes when turned on is the coolest. Too late to cook anything tonight but steaks for lunch tomorrow :)
Not just a sammich, but a HC vertically integrated sammich. Noice.
Is that proscuitto hiding in there or did you go vegan on us?
Chicken Tandoori with curry winter squash. Wow, this plate disappeared fast.
So, I simply put these in a pot with the Anova doo-hickey, and they will taste better?
I would do 72 hours at 212, for optimum bettering.  Don't use a vacuum bag, just dump it straight in.
... Then a final smoke on the grill?
