Bryston BHA1 Headphone Amp
True, though relying on software knocks out a lot of source options (or you're back to adding more hardware in the path).
Forgot about that. I have always had a computer as a source, so I was looking through that lens exclusively by habit.
This also has Bryston's 20 year warranty since it is an analog product. That's always nicesmile.png
Edited by roadtonowhere08
  • Replies 101
  • Views 46.5k
  • Noise cancellation of COMMON MODE noise happens wherever the phases of the signal are compared. If the phases are compared at the inputs, noise cancellation happens there. If the phases are compared a
  • No, it means that there should hardly be any difference at all. Which is very cool. Ooh, unless the output impedance is different running SE and BAL. People put WAY too much importance on Bala
  • Thanks for the explanations, all. It is much appreciated. My balanced cable came in and is now connected to my LCD-2s, and I'm enjoying it quite a lot, design issues notwithstanding. Semi-ignora
From the brochure:
Power Options:
• Standard: high quality Bryston internal analog
power supply
• Optional: MPS-2 power supply also available
(replaces internal supply)
The amp itself is listed at $1295, but the price will hit $3K once coupled with the additional MPS-2 ($1695) power supply.
Edited by purk
I imagine "Canadian sound" as very polite with a cold top end and most of the energy toward the bottom.
The DMX515 protocol uses male XLRs (XLR-3 or XLR-5) for the output and female ones for the input.
Very interesting. No reason to switch from the GSX but....
I'm the same way. I sure hope that my Gilmore Reference Balanced can still edge out the Bryson.
or what, you turn into a pumpkin? heh. that statement just struck me as funny for whatever reason just now.
At least for me, I'm not expecting to hear the difference, it's just something new (which has it's own value). The stack a BDA-1+BHA-1 would look pretty damn sick. Though I wonder if they have sorted out the weird behavior observed in the Stereophile review of the BDA-1. Who knows.
You are reading a little too much into it laugh.png But if the Bryston sounds any where near the GSX and come with 20 year warranty, it isn't a bad choice.
the 20 year warranty makes sense with Speaker systems, but does anybody keep headphone stuff that long?
Not really, but it is a peace of mind knowing that the investment you made is well protected. Plus it certainly will help the resale value as long as the warranty is transferable.
Any idea what this means?
6 Fully discrete Class A Bryston operational amplifiers
The opamps are their design? Maybe that explains the uncommon power delivery depending on the impedance. in any case it seems "powerful enough".
power ain't the problem with most dynamic headphone amps.
Nor electrostatic ones for that matter ;D
From the brochure:
From the audiocircle thread (page 21):
Quote from: MellowVelo on 5 Dec 2011, 05:21 PM
Hi James,
Is there actually a difference in the level of sound quality between the internal-PSU version and the external-PSU version? Or is the external-PSU version just offered as a convenience for customers who already have the MPS-2? If there is a difference, what is the difference in terms of percentage? I know that that's pretty subjective, but if the external-PSU version offered 100% maximum sound quality, what percentage would the internal-PSU version offer?
Thanks!
Hi,
Correct - just a lower cost alternative for folks with a MPS-2 already.
james
Seems pretty clear. He's saying one or more of the statements in those four questions is correct.
I think there is 2004 HF thread that might explain this a bit where Kevin commented, but they have a discrete opamp design (think Burson) they use in their designs to impart that Royal Mountie sound.
That answer confuses me.
laugh.png Yeah, it was rather nebulous!
I am betting he was saying that for those that already own an MPS-2, the version with no internal power supply is a cheaper route, since getting one with an internal PSU is redundant. Now, I am not quite sure if any of the design has changed since that remark, but I think it has not.
For those that do not own an MPS-2, the internal PSU version would be the equivalent. The only difference is that the MPS-2 can power 4 devices at once based on the number of power outlets at the back.
I really do not think getting both will yield any audible results over just getting the internal PSU version.
true. the Justin Wilson warranty is worth a bit, though, since we can go and murder him if necessary.
Or worse, cut him off from cheeseburgers.
I'll save you Nell!
5 on a balanced amp seems insanely high to me, and I don't listen at churchmouse levels like you do Nate.
If we're going on the assumption that 5 equates to an effective 10 given the balanced configuration then I revise my previous statement, having the low gain option set that high is unlikely to yield good results.
I'm also not a fan of parking the outputs right next ot the power transformer. Where's the logic in that?
