Amplifier porn
Apart from the fact they take the battery supply and put it through AC regenerators (the things screwed to the wall). They go to the sockets supplying power to the wall sockets, and go to the power transformers in your audio gear.
The only benefit is a pure 50/60Hz sine wave rather than the grotty looking thing that comes off the grid, with flattened tops and spikes..
The real way to do it of course is to use the batteries as the DC supply to the amp and dispense with all the AC stuff. As some serious DIY'ers have done for decades, powering their gear directly from a rack of car batteries.
  • Replies 577
  • Views 185k
  • Knuckledragger
    Knuckledragger
    "I inherited my late father-in-law's system and need some guidance." says a redditor.  The system: Some father-in-law.  I married the wrong woman.  "Knuc
  • Craig Sawyers
    Craig Sawyers
    Designed by a guy called Steve Sells. I hired Steve straight from University back in around 1990 when I was running Engineering at Wharfedale. We were planning to re-launch Leak, and I said to Steve "
  • Knuckledragger
    Knuckledragger
    1977 Nakamitchi System-One.
There is no way for me to prove this but I am willing to bet big dollars that the reason some times the same gears of mine sound much better (or worse) than other times has to do with the quality of the AC power from the grid at the time.
Would be great if someday the battery technology is such that we can power our audio gears from DC supply that's totally isolated from the AC grid.
A big enough lightning strike can always span an air gap.  Otherwise that technology already exists.
Craig, yeah, that’s exactly what I meant by “something like that” — hacking the power supply chain (or designing the system) to eliminate the need for AC.
How clean and non-RFI free the mains power regenerator in the Powerwall is will be the kicker for the unit in high end audio. As far as I know, a user cannot access the 48V battery as a DC source.
It is one hell of a chunky battery though - 125kg (about 275lbs)!
yes, the technology has existed for some time but I am hoping for the technology to be more accessible (cost, size, etc.) and better usability.
Some recording studios used to power their consoles with a closet full of car batteries.
But that was motivated by hum and other local circuit issues.
I experimented with powering my Metric Halo interface/ADAC with a car battery. It worked pretty well but I can't say there was any obvious advantages.
I sure would like to see someone design an "all house" dc supply so we could forget about all these friggin wall warts.
Buying these POS dc power supplies over and over.
What a waste!!!
Pretty good room heater too :P
At points in the past I have had fan cooled Krell and Audio Research power amps. In the UK where no one has or really needs air conditioning. So in the Summer, running either of those hernia-inducing monsters needed real dedication to the audio cause.
I had a Marantz cassette deck which was the immediate predecessor of that in this picture. They were about the same, just slight changes in the VUmeters colors and the action buttons. More than 40 years ago. Time flies.
Three cassette decks in a row, I smell a new thread theme.
