Watches
I'd check it before buying, it's not as much as if your wrist can wear it, but if its own size won't look as a clown watch. IMO watches over 42mm tend to look pretty excessive, even ridiculous.
  • Replies 3.7k
  • Views 749.3k
I tried one on and it wasn't THAT crazy, but I get your point. I'll look around - Tissot has a Seastar Quartz Chrono which is 44mm. Doesn't look too different from the big auto.
Edited by RudeWolf
Hard to judge the size ones' self wrist. I mean it's the same thing dangling in front of you for decades...
pAPsOKd.jpg?1
The other Zenith my best half got me for the 50th birthday [emoji3]
I've got the same movement in a different package I believe.
Beautiful Zenith Antonio, you are obviously a man of taste, sophistication and class.
One question though, why are you here?  :P
Because I have a tough time finding people to get along and you're just them ;D
OTOH the watch was the wife's choice. I wonder what's she doing with me.
Edited by Torpedo
Omega in Maine :)
Marc ...
I know exactly where you were ... Spring Point Light in So Portland.  Great place to walk out to, and then around the old Ft Preble which is now So Maine Community College.  Used to live right around the corner from there.
It's great you noticed the problem before it damaged the watch. Maybe that's a winder's design fault, people have large watches these days.
http://www.mvmtwatches.com
have any of you heard or know of these? i know nothing about watches and this will be the first real watch I've ever wore. Looking for something simple, classy, for work as well as going out casually.
Got this in the other day - a 1960's Omega Seamaster 300 from NOS parts except for vintage Omega 565 movement (from Watchco), which included an 1171 bracelet and a shark mesh bracelet.  I was lazy and put it on the first NATO I could get to.
It's only gained 1.4 seconds in the first 24 hours on my wrist, and the lume glows like a torch after being in the sunlight and then going inside or into the shade.
Good job.  I typically wont touch the watch head/case myself, but I've brushed many bracelets in the past.  That's a wild story about what the watch and ring have been through, and I'm not just talking about the VW motor (bad watchmakers are all over the place).
I always make sure my watchmaker is comfortable restoring the finish to factory, or only cleaning it up without touching the deep stuff to avoid softening the edges. I tell him it's okay if he thinks someone else could do a better job, but so far he's never let me down.  It's possible that if you wanted to totally remove the marks on the bracelet that it could be burnished or laser welded and then re-brushed, but those marks are part of the history of the watch and probably not visible without a 2x loupe or higher.
I installed the 1171 bracelet on the Seamaster 300 today.  I might like it better on the NATO, but that strap was either too loose or too tight with the hole spacing.  So far it has only gained 2.0 seconds in 48 hours while on the wrist, so it's a keeper.
Yeah, I have no interest in removing those scratches.  There are smaller ones of the north side of the watch, too, but you wouldn't notice them if you didn't know about them.
That Seamaster looks great!  That appears to be the same bracelet as my '69 Speedy.  If so, it's super comfortable, but rattles.  If it's the same bracelet as my Speedy, it should have about the same adjustment on the clasp as Rolex up until the mid 2000s.
Yes, it's also the same bracelet that came with my 1976 Speedmaster.  Some earlier 68-69 Speedy bracelets have sharper more rectangular edges on the links, and some have this 1171 with the more rounded edges on the links.
I was able to adjust the clasp to the second from smallest setting, and not have to remove any links for my 7.25" wrist.  I think it could adjust between a 7.12" to 8.25" wrist without ever touching the links, with the smallest setting fitting my son and the largest setting fitting my brother (or you).
That's how it is with mine.  I wish my 1999 300M had the same clasp!  I know that Nate wishes his early 2000s had the same clasp as that, too.  It's hard to get a good fit without the micro adjust.
I also added a Strapcode micro-adjustable clasp to the shark mesh on my Seamaster Pro ceramic chronograph today.  I'll get some photos soon, but I'll be able to expand the bracelet when my wrist swells up in the heat of summer.  It's not tight right now, so it may become too loose for this coming winter.  But I can remove another row of links from the 6 o'clock side, at which point I may have to leave it slightly expanded all the time during the summers.
Hah, I didn't even know such a clasp existed!  You're a wonder when it comes to watch stuff, my friend.
Here you go!  Strapcode 20mm expanding bracelet clasp in 316L
I used a $60 eBay shark mesh for the decent chain mail portion, and replaced the clasp which was decent (all polished stainless, looked high quality). The links look about as nice as the ones on my two Omega shark mesh.  The $25-30 shark mesh on eBay are much poorer in quality, with mismatched link sizes so the rows can look slightly diagonal and it doesn't bend right.  So total bracelet cost was about $130.
Edited by HeadphoneAddict
add details
