November 27, 200817 yr I thought it might be kind of helpful to have a thread of your least favorite parts so everyone else can avoid them. For me, right now it's the Switchcraft TA3F mini 3-pin XLR connector for AKG headphones. Piece of crap is made of metal and bad plastic and is breaking/falling apart on me. But there's no alternative available
November 27, 200817 yr neutrik locking jacks... ugly and pretty much useless imo cardas 1/4" plugs.. hard to solder the ground
November 27, 200817 yr Cardas GRFA rca sockets are a pain to works with. You need to sand the shell to get a good contact which is just .
November 27, 200817 yr Death and taxes. Hangovers. Impotence doesn't sound like much fun. Oh, and Jazz obviously.
November 27, 200817 yr Eichman banana plugs. It may be designed with sonics in mind using 24k Gold plated Tellurium Copper, but the POS plastic stalk is fragile, bending and threatening to break off with heavy speaker cables. Worse yet, the metal strip slips up and down easily if there is resistance in the female banana jack.
November 27, 200817 yr Eichman banana plugs. It may be designed with sonics in mind using 24k Gold plated Tellurium Copper, but the POS plastic stalk is fragile, bending and threatening to break off with heavy speaker cables. Maybe you're using them in the wrong application.
November 27, 200817 yr Maybe you're using them in the wrong application. Yeah, they're a lot better to pick your nose with.
November 27, 200817 yr Maybe you're using them in the wrong application. I'm pretty sure I'm using it according to manual to a *T*
January 21, 200917 yr I'm pretty sure I'm using it according to manual to a *T* Looks more like "Turkey Jerky" to me!
January 21, 200917 yr Kobiconn female 3.5mm(1/8th) audio plugs from mouser. The plastic melts easily when soldering hookup wires, even at low temps. Does anyone know of a teflon 3.5mm plug?
January 21, 200917 yr 2sc3381 - there are apparently 2 versions (7 legged, which I need, 3 legged which I do not, but got 50 for my trouble), and once found and paid, actually getting them. Have 3 payments out with vendors, and no parts to show for any... some since November. You'd thunk I'd ordered from Singlepower. Yes, I know BDent, etc, but lots of others claim stock... until you actually expect delivery. Now i did luck into a couple of 2sk389, just for the old BH, though LSK is for the new kid.
January 21, 200917 yr 2SC3381 datasheet doesn't show any 3 legged for this... it would be kinda hard to pinout 2 BJTs using only 3 pins I hear ya on finding these... I was trying to get more in case I decided to do Dynamite. I decided to just do 2 ch Dynahi instead. Use 2SC2240 pairs to replace these (2SA970 is the complementary). Edited January 21, 200917 yr by Pars
January 23, 200917 yr Cardas GRFA rca sockets are a pain to works with. You need to sand the shell to get a good contact which is just . You mean like these? I was considering buying these
January 23, 200917 yr You mean like these? I was considering buying these They look pretty, and beefy, but you need a blowtorch to solder to them. Never again. I do like the Kimber a LOT better.
January 23, 200917 yr You mean like these? I was considering buying these I bought a soldering iron just for these jacks. The blue Hakko dash works fine with the stock, giant tip. I think it's like $30.
January 24, 200917 yr I've got a Hakko 936 and a wider than stock screwdriver tip (1/8"). Hmmm... you'll be fine then. Is this all you need? I might have a pair laying around somewhere, perhaps I can save you a few bones on shipping and what not. Otherwise, you might shoot naamanf a PM, he might be able to help you...
January 24, 200917 yr The perp has 3 pairs of these... I didn't have an immediate application but will need some for: Dynahi (2 ch)Aleph P1.7 (at least 1 SE input, and an SE output as well)Rotel 855 when I get around to replacing stock jacks So I figured at that price, they might be nice to try. I need to sit down and finish something also
January 24, 200917 yr The perp has 3 pairs of these... I didn't have an immediate application but will need some for: Dynahi (2 ch)Aleph P1.7 (at least 1 SE input, and an SE output as well)Rotel 855 when I get around to replacing stock jacks So I figured at that price, they might be nice to try. I need to sit down and finish something also diyAudio Forums - FS: Cardas female RCA (GRFA S Thick) - Page 1
January 24, 200917 yr Yes, shipping is high, unless you shoot the perp an offer Spritzer or any else who has used these: I read a review on diycable.com that claimed the rhodium (and silver) scratch off of these rather easily. Also, these are the S with the thick nut (0.00"-0.082"), so will not fit my intended enclosure which has a 3mm back. Do you know if you can buy the nuts separately? If I could get the thin nuts, the range expands to 0.079"-0.142" IIRC, which would be a bit shy of 4mm. I dunno, these seemed like a good idea, but I am now leaning away from doing them.
January 25, 200917 yr I used some sandpaper to get the solder to stick and I don't know if you can buy the nuts separately.
