November 11, 200917 yr comment_295221 Ditto but I will change it to a BNC soon. BNC input on my Audio Sector Dac1 Report
November 11, 200917 yr comment_295228 Optical when on my desktop (ibasso D1 - sounds better via optical rather than USB) and usb (Pico DAC) when on my laptop. Report
November 11, 200917 yr comment_295247 Not currently using any, but will be soon. I like AES/EBU. I found that it sounded noticeably better than the coaxial input on my last Opus DAC. Report
November 11, 200917 yr comment_295282 USB - COAX RCA - COAX RCA. (Trends UD10.1) - (Sony DAC) Neither has BNC. Report
November 11, 200917 yr comment_295301 Where is the option for it doesn't matter? If you have decent equipment, then you should be able to use any connection method without too much stress. Sure, you might be able to see jitter or a sloppy SPDIF signal on a scope, but IMHO audibility of such things is tenuous at best - unless you are very specifically listening for it. Report
November 11, 200917 yr comment_295305 Mac-Mini --- Dac Magic ----Toslink because thats all that will work SB3 ---- Overture ----- Toslink because thats all that will work Netbook ------ Pico ----- USB because thats all that will work Transporter ------ CA 840c ------ Coax RCA because I can I let the majority carry my poll vote Report
November 12, 200917 yr comment_295343 BNC, Because Nicaraguans Can, that's why. True 75ohm ftw, that's right! I said it. Report
November 12, 200917 yr Author comment_295349 RCA or USB if Pico. Why do you ask? There's another thread where we're talking about digital inputs being up to spec, and I wanted to put my concerns that my method is vastly inferior into perspective. Thanks Beefy Report
November 12, 200917 yr comment_295450 Toslink Optical from Macbook Pro Coax RCA from CD player Easiest options. Report
November 12, 200917 yr comment_295476 Smoke signals, because my music collection is currently in the hands of apache indians. Report
November 12, 200917 yr comment_295482 I voted RCA coaxial SPDIF since it's the most used link between the CEC CD transport and the Bidat DAC, or the Sony ES player into the DA11, but I'm using other connections depending on the setup: Computer>USB>Lavry DA11 CEC CD Transport > AES/EBU> Lavry DA11 Sony CD > Toslink> Bidat Report
November 12, 200917 yr comment_295487 Firewire (iMac to Duet) Coax (Squeezebox into Denon receiver) Report
November 12, 200916 yr comment_295558 anyone tried HDMI out from their computers to A/V receiver? Report
