Blue Hawaii Special Edition
  • Replies 1.5k
  • Views 394.9k
  • luvdunhill
    luvdunhill
So how many watts will the BHSE pull from the wall? ;)
If Chuck Norris were an amp, Chuck Norris would be a BHSE!!
Wow. The phrase "The Few. The Proud" comes to mind.
BTW, is that preamp output I see on the back, and if so, how does it sound? (poor audiofool trying to justify purchase in 'stat/speaker system)
Loop Output
Something like 150-200w. In case you are wondering... this is a serious headphone amp. :cool:
So about 2x ~ 2.5x as good (as a room heater) as my KGSS. :o
meh. I'd guess 80W-90W (I don't know what the CCS are set at in this version, hence the range)
If I ever design an amp I'm going to put a giant heat sink with a resistor that takes 1000w from the wall. More power is always better :)
:o Great sound and keeps your coffee steamy. 3rd degree burns come to mind.
I think MOAR POWAH should become a brand name.
don't forget the filaments, power supply regulation, and transformer inefficiency
my guess still stands :)
wat? the standard BH is 10W bias per tube
10W CCS x4 = 40W
10W EL34 plate x4 = 40W
1.6A x 6.3V x 4 = 40W
voltage regulation = +15%
transformer efficiency = +15%
total = 166W
then add in the -300V regulators, a couple watts for the +/-15V, and its easily 175W
10W CCS x4 = 40W
total = 166W
:palm: 80W-90W per channel, obviously :palm:
