Blue Hawaii Special Edition
I just got everything setup and then took a shower - now I have to wait for the hair to dry to listen.  :(
  • Replies 1.5k
  • Views 405.2k
  • luvdunhill
    luvdunhill
It's dry and I'm listening.   Maybe I should shave my head so I don't have to wait in the future. :)
I have had the BHSE on for several hours and I noticed that the underside of the top shelf is really warm (the shelf above is only about 3/4" above the BHSE).  Can a lot of heat make the shelf above become weaker (so that it cannot handle as much weight without cracking/collapsing).  I was trying to avoid putting the BHSE on the top shelf because of fine white dust in the apartment.   I don't really have much on the shelf right now but might but the BHSE on it in the future if I buy another place without concrete ceilings.
Edited by shellylh
I am more concerned about putting a75 pound object on it in the future (or someone putting a lot of weight on it) and it breaking on top of the BHSE.  I hadn't even thought about it catching on fire.
Hmm, just saw this post from Justin on HF:
http://www.head-fi.org/t/439657/headamp-blue-hawaii-special-edition/1830#post_8348709
"for testing I stack the BHSEs on 3 shelves (see a pic several pages back or at www.facebook.com/HeadAmp) which are spaced about 16" apart and there's no difference in temperature between the amps on the 3 shelves.  so i would recommend at least 8" of air above the tubes if the amp is on a middle shelf"
Yes, but there is a lot of dust (very fine white powder) in my apartment (I think from the concrete ceilings) and I am worried about getting the dust/white powder in the amp.  I would think that would be worse than having it on the second shelf.
No.   I can buy another rack.   I can buy a fan and point it at the BHSE when it is on.
I just felt the top of the top rack and it is even hot.  Hmm.
Edit: I've always liked the look of the Salamander rack (the spacing between racks with 3 shelves is probably around 12 inches, I have 9 inches right now).
http://www.audioadvisor.com/prodinfo.asp?number=SMA3
Edited by shellylh
That shelf looks easy to make;
Four theaded M25 rods 1500mm or so
20 x M25 nuts
8 x M25 domed end cap bolts
3 Marine plywood shelves 25mm thick
Find a local wood shop would cut and drill the shelves if you don't have the gear.
20 x M25 nuts
No way I'm DIYing a shelf that holds the BHSE.  I am seriously lacking in building skills.
20 x M25 nuts
Isn't that the recipe for...dang, I forget the name of it now.  The DIY shelf that all the DIYers here put together one.
EDIT:  v Yes, what grawk says.  "Flexy".
I made a rack very much like this many years back, with white top laminated MDF shelves.  I added plastic washers so the nuts wouldn't mark the shelves as badly.
I also only used 3 rods, as I liked the tripod balancing (and less holes to drill); even though the back rod would in theory be in the way of the wires, it wasn't bad at all.  I did end up putting foam pipe wraps around the back rod, though, so wires wouldn't rub and scratch on the threading.
All in all, was not that difficult to do!  Gave it away when I moved to our new house, but often thought about making another......
You will have to assemble that rack.
I'm pretty sure I can assemble a rack, just don't want to find/order the parts and have someone drills hole for me, sand/paint.... that's a lot of work and $200 isn't that much money.
16 minutes ago, tyrion said:
Sent from my iPad using Tapatalk
Is the setup at your house Mike?
I'd put the BHSE on the second shelf, the BHSE PS and Apex Peak/Volcano on the bottom shelf and the PS AUdio PWD MKII on top.  Do you think it would be too top heavy like that (the PWD MKII is pretty heavy).
I can confirm that the SolidSteel racks hold a BHSE just fine.
