Closed - KGSSHV Carbon and GoldenReference HV PS Group Buy
  • Replies 419
  • Views 98.5k
  • Yep, this has to be the most confused/confusing GB I've seen. From simple concept to kitchen sink...   EDIT: it was suggested in a pm that I might want to elaborate on what I find so confusing. I do
  • Thanks all for your prompt responses and payments.  I sent PCBnet all the latest version Gerber files yesterday for final confirmation of quotes. I will place the order soon as I receive the confirmat
  • I have built one of the Fat PS boards , kgsshvpssicfetsinglenewrightfat gerbers dated Tuesday, ‎July ‎28, ‎2015, ‏‎2:38:28 PM and want to report that it works... 408vdc at anything above 310vac input,
Payment sent.
Awaiting shipping costs to Australia.
Thanks for all your trouble
In rgrds to caps GB, it seems to have settled around 175 caps in total. I have negotiated that we get the same price as the +400 pieces quote.
Please update the sheet with country, postal code and date for confirmation of the amount: https://docs.google.com/spreadsheets/d/1GWDWwLfsIDtwn1HB-x76lS6WyWwLd5lwsORFKiUuuEQ/edit#gid=2024111922
I'll calculate estimated shipping based on location information.
Thanks
Paid, thanks!
BTW, did not include an address, but I think you have mine from the pair of multiamp boards.
Details included
Thanks
Is the caps GB still going?
I can't edit the google sheet.
The amounts has been locked ... pm if you wanna change, please
I'll do a separate thread on the Caps GB in order not to make too much confusion.
Edited by sorenb
I sent PCBnet all the latest version Gerber files yesterday for final confirmation of quotes. I will place the order soon as I receive the confirmation which I expect in a day or two.
I will keep you posted.
408vdc at anything above 310vac input, bias is also good.
I have found that zeners tend to run at a higher voltage than rated when warm... plus there's the 5% spec. Did you hand-pick them to be as close to the called-for voltage as possible? Do you find that the bias gets up to >600V after warming up?
posted for congo5
power supply board known working as expected from kerry's and my prototypes
for the 400v version, input AC needs to be at least 310vac
which would make 350vac necessary for the 450v version
so with clearance i would pick
360 vac under load for the 400v version (500v caps sufficient) and
390 vac under load for the 450v version (550v or more caps sufficient)
Great news, and quite a relief it is, thanks a bunch Congo5
Not using  this board for a while, if at all..
But of the 5 amps here, I  have not seen any over 600v  when warm.
but will check again, I would think 5% would be fine.  550v-610v
easy enough to change one for 20v lower or higher
also how do I know which of my 7 or so Digital Multimeters is right?
Wouldn't even 10% be safe for the phones?
