September 28, 200818 yr comment_164568 This is pretty much the first time I've had a chance to spend any quality time with the Pico DAC prototype that Justin was kind enough to send me since I've been out of town all weekend. My system in transition at the moment so I only have the Duet as my headphone amp and won't have me monoblock back for my speaker rig until Wednesday. At the moment I'm using the mini out of the Pico for my 650's with the Pico connected usb to my Mac Mini. I'm using the volume control of itunes to control the Pico. I realize this isn't the optimum set up but it's the best I can do until later in the week when my speaker rig is back in action. I have to say that Pico sounds great. I switch between it and the Duet, switching between the two dacs in system preferences and the Pico is every bit as good as the Duet and perhaps a bit better in detail retrieval. This is just preliminary and I will do a lot more listening but I am pretty impressed with the sq so far. Especially considering that it's using the volume control of the Mac Mini without an external amplifier. That is it for the moment. Report
September 29, 200818 yr comment_164569 Great. Looking forward to your impressions. Do you happen to have a non-DAC-only Pico (nDoP) to compare also? Report
September 29, 200818 yr Author comment_164570 Great. Looking forward to your impressions. Do you happen to have a non-DAC-only Pico (nDoP) to compare also? Nope. That will have to wait until November 15 at the Tampa Meet assuming Justin let's me hold onto it for that long. Report
September 29, 200818 yr comment_164571 And I just got a Duet, too. Maybe I'll just get one (Pico DAC) when it goes in production to do a three-way comp with 840c and Duet. Report
September 29, 200818 yr Author comment_164573 And I just got a Duet, too. Maybe I'll just get one (Pico DAC) when it goes in production to do a three-way comp with 840c and Duet. Nothing wrong with the Duet and it's too early to declare a winner between the Pico and Duet. Report
September 29, 200818 yr comment_164579 I wonder if said prototype could make it down to Houston on Oct. 25th? Report
September 29, 200817 yr comment_164710 Thanks for your thoughts Mike, looking forward to hearing more about this new unit. Report
September 30, 200817 yr Author comment_164919 I should be up and running with at least my speaker rig tomorrow so I will try to get some more impressions in the next couple of days. Report
September 30, 200817 yr Author comment_165006 Here is the Pico in my temporary stat rig: I'm still unable to compare to the Duet in this setup but the Pico is definitely not disappointing. I wish I had a decent cdp here to compare it to. I guess that will have to wait for the Tampa Meet. Report
October 1, 200817 yr comment_165192 And just when I was gonna ask if it looked any different from the regular pico, you go and post some pictures. Thanks! Any details you can offer about the prototype? I see it outputs RCA, what about input? Report
October 2, 200817 yr Author comment_165218 I have my speaker rig up and running. The Duet's output is higher than the Pico so using a sound level meter I and a Cardas Burn In Sweep I was able to volume match by lower the output of the Duet. I've spent about the last hours listening to about 4 or 5 tunes over and over again. They include Alison Krauss Let Me Touch You For A While, Lucky One. Miles Davis So What. Albert King/SRV Call It Stormy Monday, Pride and Joy. My preliminary conclusion is that those of us that own Duets are going to have a tough time deciding whether one is better than the other. I haven't picked out any real differences between the two but it's only been an hour. I would find it difficult to believe that anyone that owns a Duet would walk away from a comparison saying the Duet is the better dac. They both do everything so well, especially keeping my toes tapping. I have more listening to do and maybe my opinion will change over time as I get used to the Pico but for now, my hats off to Justin. Report
October 2, 200817 yr comment_165255 pico wins. because you can use it with pc's. duet = epic fail. because you can only use it with macs. Report
October 2, 200817 yr comment_165267 pico wins. because you can use it with pc's. duet = epic fail. because you can only use it with macs. Perhaps, but Duet also works as an ADC. Report
October 2, 200817 yr comment_165270 duet = epic fail. because you can only use it with macs. Don't get all uppity just cause you picked a crappy laptop. Report
October 2, 200817 yr comment_165279 Don't get all uppity just cause you picked a crappy laptop. I don't care much about PC vs Mac, but it would be great if they would do another commercial based on that emoticon. Report
October 2, 200817 yr comment_165328 Don't get all uppity just cause you picked a crappy laptop. I don't care much about PC vs Mac, but it would be great if they would do another commercial based on that emoticon. Excellent idea Ken, glad to see my favorite emoticon is finally getting some respect Report
October 2, 200817 yr Author comment_165422 The amp that was just returned and died again. I'm sending both monos back. He's going to build a new amp for me to replace the one that went bad and upgrade the other. I hope to have a replacement while they are gone so I can continue to evaluate the Pico. Having heard the SRD-7 mkii now for a few hours, I hope the KGSS DX is as good. Report
October 2, 200817 yr comment_165426 Jonathan Hodgman kicking Justin Long in the balls would make for the best commercial evar. Report
October 2, 200817 yr comment_165514 The amp that was just returned and died again. I'm sending both monos back. He's going to build a new amp for me to replace the one that went bad and upgrade the other. I hope to have a replacement while they are gone so I can continue to evaluate the Pico. Having heard the SRD-7 mkii now for a few hours, I hope the KGSS DX is as good. What the fuck, Mike. Did you buy those things new? Sorry for the hassle but it is big of you to stick with them. Report
October 2, 200817 yr Author comment_165515 What the fuck, Mike. Did you buy those things new? Sorry for the hassle but it is big of you to stick with them. They were new. I've had them for 5 months and this was the first issue. He apologized and said he should have ran it longer before sending it back. The turnaround was just under 2 weeks, considering some others, that's not too bad. He is a good guy...so far. I am picking up an amp from Oz this afternoon so I am good to go. Report
