Group Build: Dynafet
  • Replies 1.4k
  • Views 298k
My "?" is because I really don't know what/where I will be in the next couple of months. If I don't have to move I should be able to help out a lot. If this comes down before/during/after my move I won't be able to do much.
It would probably be a good idea to do a group buy for all the front and rear panels. Bulk discount plus it will make case work a bit easier.
Naaman,
Agreed 100% on the machined panels idea. I was really happy with the service that I got from Cam Expert and it's really a no-brainer if you can supply the material and only have to pay for the fab work.
Also depending on what people want this thing to do a I/O board with all the back panel connectors PCB mounted could also make production much easier.
Sounds good to me, although I not sure I'm ready to offer casework skills since I don't want one. But I could always just send the assembled pcbs to someone else. :)
I'm going to tentatively draw the line at the following:
10 amp chassis
42 part kits
50 boards
Time to check the part bin.... er storage closet :)
edit: can someone please check my math / read back through the thread and see if this sounds okay?
Nate, Naaman, Marc & others, any kind of educated guess as to cost of a balanced version?
One set of balanced inputs, single 4 pin balanced output...nothing too crazy.
As Nate said, oh frack it:
  • luvdunhill - 8 - 4
  • Asr - 0 - 4
  • Stretch - 0 - 4
  • looser101 - 4 -2
  • PFKMan23 - 0 - 4
  • Naamanf -? - 4
  • Icarium - 0 - 4
  • Dreadhead - 0 - 4
  • n_maher - 4 - 0
  • Digipete - [8-12] - 4
  • Pars - [8-12] - 2
Willing to help build, match parts, etc.
Anyone have a BOM for this? I notice one on Headwize done in Google docs, but it seems to need updating (which I can do??).
Edited by Pars
  • Asr - 0 - 4
  • Stretch - 0 - 4
  • looser101 - 4 -2
  • PFKMan23 - 0 - 4
  • Naamanf -? - 4
  • Icarium - 0 - 4
  • Dreadhead - 0 - 4
  • n_maher - 4 - 0
  • Pars - [8-12] - 2
Any reason you left me off?
[*]grawk - 4 - 4
I'll want parts, boards, chassis, panels, etc.
Oops, copied wrong post for list:
  • Asr - 0 - 4
  • Stretch - 0 - 4
  • looser101 - 4 -2
  • PFKMan23 - 0 - 4
  • Naamanf -? - 4
  • Icarium - 0 - 4
  • Dreadhead - 0 - 4
  • n_maher - 4 - 0
  • grawk - 4 - 4
  • Pars - [8-12] - 2
Maybe $1250-$1500 for 4-channel build? I think we need to work a BOM based on the above quantities and go from there. I will try and get some hard quotes on semiconductors tomorrow. Perhaps Pars can take a crack at the various and sundry other items.
DigiPete: What did your Dynamight build cost? I'd say an extra 20% on top of that.
I am so gonna get one of those cases, a Dynafet will very probably be well out of my pricerange because I do have to ask... very sheepishly.
As others have indicated, those of us with no knowledge of such things don't even have a general ball park figure to work from and without some rough guesstimation of cost, it's hard to commit.
*edit*
Ah, yep that price is well above my threshold. :(
Edited by Smeggy
That is well within my budget. I would like a case and all the other group buy frills as well :)
That estimate is actually quite a bit less than I anticipated. I have no friggin' idea what the heck I'd do with a Dynafet and a Beta22, but the sickness is strong, because I still want one.
I'll try my hardest to rechannel that urge into something really sensible like HD 800s.
There is no way that I could feasibly participate or contribute to this, but will watch with GREAT interest :)
Though if there is any scope for me to jump in on IO boards like naamanf made for his B22 builds, I would definitely give that some serious consideration......
man..... I stopped keeping track... but $800-900 would not be out of the ball park [DIY cost]
heh.. I was curious what you'd guys would say to that. Anyways, Pars and I will work offline to come up with part cost. Stay tuned.
Bad pictures taken during build phase, but shows the scope of what I did
Am I the only one not seeing anything?
