Sorry, I know nothing about the scope stuff, my friend did it for me. We only measured at the outputs, so low voltage. I am satisfied to the degree that my engineer friend said it looks good. I think he is pretty good but who knows. The amp works for now :)
TPI ADF15 High Voltage Differential Probe
ebay# 310329294762
$350 buy-it-now
~$150 cheaper than Tek probe, not as good though, but maybe good enough.
Maybe we should group-buy the Tek probe and share it around. I suspect that we will not often have a situation where more than one builder at a time is at the stage where construction is near completion and he needs to measure stuff.
Just a thought.
You can also get high voltage probes for your scope, much less expensive than these differential probes. 2,000 volt operating limit, 100x voltage scaling (i.e., 100:1) is under $30, I've seen probes rated to 10 KV, 1000:1 , also, same price range.
Very cool sir!
If the "new" T2 is residing in your main rack, where do you keep your "old" one? ;)
The guy who did all the soldering on it gets to keep it in his room. He is loving it.
It was like $65 a couple months ago. Tough to find a reasonable price for the thing.
they're $51.10 at the 1-24 qty, and get as low as $35.26 at 100-249 qty.
The price was $34.86 for 10 in 2006
