November 20, 201115 yr comment_481617 Thanks for all the compliments guys. The biggest thanks goes to Kevin for the great design! Edited November 20, 201115 yr by Horio Report
November 21, 201115 yr comment_481690 Looks fantastic with the front panel. Great job, Greg. Can't wait to hear it for myself. Report
November 21, 201115 yr comment_481733 Is the back panel on that case aluminum, or is that the stock steel panel? I'd like to do something similar on my dynahi, but didn't think that FPE did steel panels. Report
November 21, 201115 yr comment_481768 They didn't when I bought my Dissipante, but yes, I was aware that they do offer them now. Hence the question. Report
November 21, 201115 yr comment_481771 There is a bit of a cost premium, but Modushop does offer the Dissipante cases with 10mm thick front and 3mm thick aluminum top/bot/rear panels. Its well worth the little bit of added cost in my book. Report
November 21, 201115 yr comment_481773 Yes, I would agree. Mine has the 10mm front panel, but at the time they were not offering aluminum rear panels. I take it yours is aluminum? Nice job at any rate, and thanks for the reply. Report
November 21, 201115 yr comment_481824 Mine is the all aluminum panel version (3U x 400mm deep). I also prefer the thicker aluminum panels, as they are a little stiffer than the much thinner steel panels. Report
November 21, 201115 yr comment_481828 Thanks. I just looked and the aluminum back panel and a top panel would run 59 euro shipped. Not likely. I wonder how well FPE's anodized panels match up to these? Report
November 21, 201115 yr comment_481834 The problem with anodized FPE panels is the exposed raw edge unless you elect anodizing after finishing which is a huge add IIRC. Report
November 21, 201115 yr comment_481836 I think FPE will be more even for just the panels. If you have a silver case I think the shiny edges look cool. I can see it being undesirable if you have a black case though. Report
November 21, 201115 yr comment_481841 They do offer to smooth the edge for 3 dollars though, the finish isn't too bad. But yeah, doesn't look good on black. Report
November 22, 201115 yr comment_481852 Of course the case is black. All I really need done is painting or silkscreen or something to look like your rear panel. Not in a huge hurry, so I'll keep looking/thinking. Shipping from Modushop for a pair of panels is more than the panels themselves... damn Italian post. Report
November 22, 201115 yr comment_481853 http://www.frontpanelexpress.com/fpd-doc/en/fpd_rawmaterials_alumnium_powdercoating.htm (the edges will be black if you choose to have the panel powder coated) Report
November 22, 201115 yr comment_481855 ^ Do they do engraved lettering (and filled) over this? And how closely would this match an otherwise anodized enclosure (or I guess painted in the case of the top and bottom panels). Starting to sound like just getting the aluminum panels from Modushop might be the way to go. Edited November 22, 201115 yr by Pars Report
November 22, 201115 yr comment_481875 I wouldn't count on it matching. I have had bad luck with this... I'll post some pics in a few weeks of the project when it's done and I think it's quite noticeable. Report
November 28, 201115 yr comment_482995 Front panel back from laser engraving. Still need to do some machining on it to get the volume pot to fit but it came out ok. Edited November 28, 201115 yr by spritzer Report
November 28, 201115 yr comment_483032 Beautiful job, Spritzer. I applaud the choice of silver. What does it say in the lower left corner? Report
November 28, 201115 yr comment_483033 Very nice Birgir, I like it. Feel free to contact me if you ever decide to get rid of it Report
November 28, 201115 yr comment_483036 What does it say in the lower left corner? The 'M' is hard to read, but I'm pretty sure it says "Mjölnir Audio". It sure would make sense for somebody whose middle name is Thor. Edited November 28, 201115 yr by guzziguy Report
